A little progress today! I got the crosstable, z-sled and spindlenose back from heat treating and today i filled them with epoxy granite:
Attachment 478632
... i've been very concerned with the parts "ringing" A LOT when i hit it with something, it is after all just plain steel. BUT after i filled them today, the ringing is almost completely gone! I hope the result is as good when the EG is cured, but even if it is not quite as good, i bet it is still a huuuge improvement...
I've used the opportunity to test if could degas the epoxy granite mix using vacuum... but no, i could not:-( I have a vacuum champer from my previous carbon-fiber endeavours and i tried pulling a vacuum on a small bucket of EG. The EG grew like 20-30%, so there is a lot of air inside, but the air wouldn't degas from the EG. It didn't buble as it do when i degas resin for carbonfiber infusion, it seems like the EG-mix isn't fluid enough to let the air out, so it's trapped in the mix, even at full vacuum.... So vacuum-degassing EG- is apparently a no-go... Just thought anyone passing by should know :-)
/Thomas
