587,531 active members*
3,549 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X2 cnc finished for now maybe
Page 2 of 53 12341252
Results 21 to 40 of 1045
  1. #21
    Hey There,
    Thought I would upload a .zip of the cad drawings as bitmaps
    and the engraving tutorial in high resolution.
    Looks alot better than what can be posted here with the size limits.
    includes 17 images.
    later Hoss
    Attached Files Attached Files
  2. #22
    Aug 2004
    115
    Hoss....Great job. Both on the conversion and the detailed explanation of the process. Yer tops, JRouche
  3. #23
    Hey Fellas,
    If you're looking to make some custom plastic covers for your steppers
    or whatever, I found(with help from this forum) some sites that sell
    thermoformable plastic. Heat it up, form it into the shape you want and it'll stay that way when it cools.
    Found several different types that pretty much do the same thing.
    I ordered from here, good size selection and pricing.
    http://www.usplastic.com/catalog/pro...uct%5Fid=12070
    This is a site for Kydex, but have a $50 min. order or you get charged an extra $15 for a small order.
    http://interstateplastics.reachlocal...D=Kydex-Ca2009
    This site has lots of plastic as well as many other stock, aluminum,brass,steel etc.
    http://www.smallparts.com/?020
    I'm going to order some Sintra PVC sheet from these folks too, lots of choices and good prices and no min. order. Get up to a 4' x 8' sheet if you want.
    http://store.foamboardsource.com/sin...a-pvc-3mm.html
    Later Hoss
  4. #24
    Dec 2004
    1137
    Or, call your local sign shop and ask them Tell them what it's for and they may just give some to you since you won't be competing with them. You can make a DIY strip heater using an electric stove and come cardboard. Have a look at Step 4 here http://www.sciencetoymaker.org/prism/assembl.html
    Like I said, I used a hairdryer to heat mine up, but you can use hot water too.
    Look forward to some photos.
    Jay
  5. #25
    Dec 2004
    1137
    Quote Originally Posted by hoss2006 View Post
    Here's an update. Got another 3/4 inches of travel on the Y with a modification
    to the base. This gives me 4 7/8 x 8 1/4 travel for the X2.
    Better. I'll live with it for now till I run across an old cross slide to adapt to it.
    Maybe Little Machine Shop will get the X3 base for sale.Keep my eyes open.
    Have Fun, Hoss
    Hoss,
    Most of what I've read about using ballscrews on the X2 say that one needs to mill the bottom of the table for the x-axis not to fit. Did you do this? Do you have a photo of the before and after?
    Jay
  6. #26
    Hey Jay,
    You do have to remove a little material from under the saddle to give
    clearance for the ballnut. I just used and angle grinder.
    Here's a pictorial that hopefully explains it. I didn't take any pics of the before
    and after, but was able to compile something close. Hope this helps.
    Also have a high res .zip of the drawing and the ballnut stop blocks rev B.dxf
    that shows changes I made to the X Axis block to give more clearance.
    Later, Hoss
    Attached Thumbnails Attached Thumbnails x axis ballnut clearance (Small).jpg
  7. #27
    Dec 2004
    1137
    Hoss your the man.
    Jay
  8. #28
    Hey Gang,
    Finished my High Speed Spindle Motor attachment.
    Will use it mainly for engraving and grinding.
    Used a Dewalt Laminate Trimmer Model #DW670 I bought at Lowes.
    http://www.lowes.com/lowes/lkn?actio...670&lpage=none
    It has a 1/4 in. collet ( I made an 1/8 collet for it) and 34,000 rpm.
    Very nice quality item with no backlash in the spindle.
    Has a machined housing that fits nicely in the mount that I made to hold
    it perpendicular and true.
    Below are pics of the drawings and finished parts.
    The spindle is offset 3 in. from the X2 spindle on the X Axis as it's mounted here
    but it's able to mount on either side or the front.
    This should work well.
    Later Hoss
    P.S. As you can see I need to mount the Spindle Lock I made on the front yet,
    that's next.
    Attached Thumbnails Attached Thumbnails engraver 1 (Large).JPG   engraver 2 (Large).JPG   engraver 3 (Large).JPG   engraver 4 (Large).JPG
    dewalt .125 collet 3 (Large).JPG   dewalt .125 collet 4 (Large).JPG   spindle engraver bracket.jpg   spindle engraver bracket B Rev A.jpg
  9. #29
    Oct 2005
    612
    Hoss,
    Your ideas are refreshing and you sharing so freely to the forum is very much appreciated. You sent me your plans earlier on and I will be copying your Z axis design on my X2 shortly.
    Try this link here for some covers for your Z axis column.
    http://www.littlemachineshop.com/pro...itFast=bellows
    cheers,
    Rod
    Perth, Western Australia
  10. #30
    Dec 2006
    5
    nice !!!!!!!!!
    This is exactly what I have in mind. I did not read your post before I posted mine. You say you are not happy with the size? I am planing a buid for the model 47158, which is smaller. Should I splurge for a larger mill?
    What are your plans for the speed control, this is were I get lost. Thanks for posting your motor mount designs they will come in handy.
    How about your milling speed? How does she do with alluminum?
    Great build and thanks for the information.
    Nice,
    Chris
  11. #31
    Hey Chris,
    I'm quite happy with the size of the X2, it will handle just about anything I plan
    on making, It's just the X3 is bigger and bigger is better, usually. Spend as much as you can afford, that's what it really comes down to. Plus the X1 and X2 can be handled without to much exertion but the X3 at over 300 lbs. could be a bear. I'm working on a control panel to control the mill 'manually' thru Mach 3.
    I have the speed control built in but it's manual right now, I'll figure out how to control it with g-code later. It will require rewiring to bypass the E-Stop and a Variable speed switch because If you interrupt power, the Variable speed switch needs cycled off then on again. I know the paperwork for the cnc controller talked about it,so I'll have to dig it up again. I'll post it when It's done.
    The mill can handle aluminum pretty well as the following pics show, but it is for
    light work. Can't go whole hog like at work, but this is at home.
    Heres a hint at the control panel, Should be done this week.
    Later Hoss
    Attached Thumbnails Attached Thumbnails control panel progress 87 (Large).JPG   control panel progress 24 (Large).JPG   engraver bracket progress 1 (Large).JPG   engraver bracket progress 2 (Large).JPG
  12. #32
    Hoss,
    Your conversion is exactly what I am looking for! Do you have all this info in a zip file?
    Bill
    Bill
  13. #33
    Dec 2004
    1137
    Bill, did you read the thread? Look at post #21 and #26 (nuts)
  14. #34
    Quote Originally Posted by Jay C View Post
    Yes I did, twice, I did not know if he had added everything after that post, Hmmm, Mabey I should have looked.
    Besides, it was late and I felt like this .... (chair)
    Bill
  15. #35
    Hey Gang,
    Here's some more pics of my control panel for Mach 3.
    I'll hook it up tomorrow and add my DRO on top.
    I took 2 USB controllers, an aluminum case, a bunch of switches and
    some wire and came up with this.
    I'll use Keygrabber from Mach 3 to program the buttons.
    I can control (4) 110 V accessories, i.e. the engraver, light, vacuum.
    I have a duplicate X2 Speed Control switch from Littlemachineshop.com.
    http://www.littlemachineshop.com/pro...282&category=6
    I added Jogging feedhold switches with LED's for taking long 'manual' cuts.
    Still have about 10 buttons unused available for future plans.(maybe Mach 4?)
    Next on the agenda, a surface grinding attachment. Stay tuned.
    Later Hoss
    Attached Thumbnails Attached Thumbnails logitech attack 3 circuiy city.jpg   phillips pc controller.jpg   control panel progress 94 (Large).JPG   control panel progress 95 (Large).JPG
    control panel progress 106 (Large).JPG   control panel progress 114 (Large).JPG
  16. #36
    Dec 2004
    1137
    Looks great, you don't to anything halfway do you
  17. #37
    Hey Gang,
    Have a little update for a few projects.
    Welcome to all the extra visitors c/o WillO from hackaday.com.Thanks guy.
    That's a really cool site more for the electronics side of things.
    Will be getting my own website up and running soon thanks to Godaddy.
    Will post a link when she's ready.
    Here's some pics of the spindle lock I made. Had to mount it on the front
    to make room for the attachments that go on the right side of the Mill.Changed the length of the pin so it doesn't protrude as much as in the first pic.The print shows the shortened pin.
    Also some clamps to hold down a precision vise.
    Plus a sneak peek at the surface grinding attachment.Waiting for my grinding wheels to show up from Wholesaletool.
    Later Hoss
    Attached Thumbnails Attached Thumbnails spindle lock 1 (Large).JPG   spindle lock 2 (Large).JPG   spindle lock 7 (Large).JPG   spindle lock 8 (Large).JPG
    spindle lock.jpg   precision vise clamps.jpg   precision vise clamps 2 (Large).JPG   surface grinder attachment progress  4 (Large).JPG
    surface grinder attachment progress  11 (Large).JPG   surface grinder attachment progress  14 (Large).JPG
  18. #38
    Jul 2005
    I've tried tons of different software to change an image into an engraving,
    but none gave me what I wanted in one simple program.Please let me know If
    you've found something that works nice and easy.
    BobArt Pro-X does this quite well. There is a demo version builtin to BobCAD too. I ponied up and bought is as an addon on one of their slow sales days...
    Short, you can open any supported image format and do posterization from 2 to 8 colors IIRC. You can vectorize in multiple formats too. It makes a vector toolpath out of an image, the rest is just a few clicks away.
    That was a neat feature, one I thought I'd use, but it's the embossing feature of toolpaths that I've used the most.
    --Perry
  19. #39
    Looking for a cheap Flycutter?
    You could make one like I did.
    Here's my print.
    I use a single Kennametal Carbide insert CNMG431 KC850.
    Get them here.
    http://www.jlindustrial.com/catalog/...tosearchpage=Y
    Or a lot cheaper on Ebay here.
    http://cgi.ebay.com/Kennametal-Lot-o...QQcmdZViewItem
    I hold the insert with an allen head screw.
    Later Hoss
  20. #40
    Jul 2005
    I use a single Kennametal Carbide insert KC850.
    Get them here.
    Later Hoss
    Even though this is highly off topic, KC850 is the grade of the insert. That doesn't describe the geometry or size. It looks like you were using a CNMG insert, probably a 432 or 332, the most common sizes and radii.
    --Perry
  1. Almost finished
    By steeltoes in forum T-Slot CNC building
    Last Post: 03-10-2014, 03:11 PM
  2. It's finished
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 01-14-2012, 02:09 PM
  3. Almost Finished
    By Kencor1 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2010, 05:41 AM
  4. Finished at last (well almost!)
    By Ali Kat in forum DIY CNC Router Table Machines
    Last Post: 05-27-2009, 06:19 PM
  5. X2 cnc finished for now
    By hoss2006 in forum Benchtop Machines
    Last Post: 01-12-2007, 11:55 PM
