588,616 active members*
4,140 visitors online*
IndustryArena Forum > CAM Software > CamWorks > UPG-2 compiling errors
Results 1 to 3 of 3
    May 2019
    8
    When I go thru the new source file generation using the templates, I make the modifications I need for my machine and save off as a new source and library files, I get a successful compile.
    If I exit out of the UPG-2 program and come back to my newly created source file, not even making any edit's, I get compiling errors when I run compile. I tried that after making minor edit's and being mystified why the compiler errors out.
    What am I doing wrong?
    I have resorted to always recreating all my modifications to a new template to get a successful compile.
    May 2019
    8
    Re: UPG-2 compiling errors
    Quote Originally Posted by krikrellim View Post
    Update: When I get the compile error, it says that it cannot find the library file. The library file listed has an erroneous directory path, it appears it is concatenating improperly the directory path twice. I have got UPG to successfully compile, I am not exactly sure what makes it work, other than after I open the source file, I had to save the source file before compiling, even if I hadn't made any edits, it doesn't seem to always work though
    Jun 2021
    9
    I too am having issues with UPG, Ive noticed that if you make edits in EC Editor and save then open with UPG and save it, it will compile with duplicate errors. So I have resorted to making edits with the EC editor and just compiling with UPG but now my UPG isnt even reading its own program files to operate correctly. Check out some of my threads.
