Don’t know if you found one, but unless you want to keep it all stock, I replaced that whole air assembly from Amazon for like $38. Nanpu I think is name. You loose your low-level alarm switch but what the hell. Actually I’m writing because with the stocker I had a problem with water getting past the drier cup and accumulated in the mist feed cup. Problem is, it draws up a tube from the bottom so ya end up feeding water, not oil. Not good.
