603,996 active members*
3,605 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > burrs when milling 304 ss
Results 1 to 3 of 3
hodaken burrs when milling 304 ss 08-15-2022, 03:24 PM
Jim Dawson Re: burrs when milling 304 ss 08-15-2022, 05:09 PM
hodaken Re: burrs when milling 304 ss 08-16-2022, 08:51 PM
    Jan 2013
    19
    Hey guys,
    I have kind of a unique problem I hope someone can help with... I'm side milling a small 304 ss part and the process breaks through into an id feature at one point. The problem is that when it breaks through it is laying a very thin burr (like a piece of shim stock) down into the id area. That is what i'm trying to remedy. Is there a special type of end mill/process I should me using that would prevent this?Click image for larger version.
    Dec 2013
    5720
    About the only thing you can do is change the order of operation. If possible do the internal feature after the side milling operation.
    The other option might be to do the side milling operation in two passes. One roughing pass, then a very light finish pass. It requires a very sharp tool for this to work. 304 is especially difficult to break the chips so tends to hold burrs.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2013
    19
    To be a little more more specific...This part is 6mm long by 8mm at the largest diameter. I'm running it on a swiss lathe holding it on the large diameter and have the endmill in a live drill position facing the spindle like so. for more reference, the endmill is 3/16
  1. Milling 304 SS
    By mflux_gamblej in forum Bridgeport / Hardinge Mills
    Last Post: 09-01-2012, 01:39 PM
  2. Suggestions on milling 304 SS plate
    By liftoff in forum MetalWork Discussion
    Last Post: 07-18-2011, 06:39 PM
  3. Not having any luck with 304 milling
    By zaebis in forum Uncategorised MetalWorking Machines
    Last Post: 03-11-2010, 06:03 PM
  4. drilling/ milling stainless 304
    By warfreak in forum MetalWork Discussion
    Last Post: 09-19-2009, 04:59 PM
  5. Feed and Speed for milling 304 Stainless
    By Loading in forum MetalWork Discussion
    Last Post: 12-11-2007, 12:37 AM
