588,156 active members*
4,557 visitors online*
Results 1 to 3 of 3
    Jun 2022
    Red face Beginner dumb question
    New to Mach3 and CNC.
    I am just starting to use Mach3 and Shape3D to shape surfboards.
    I searched and haven't found a definitive answer to this simple question.
    Shape3D creates the GCode file which also includes the tool starting point (from the home position).
    If I want to start the tool at the work piece (not the home position) do I have to change the GCode in Shape3D or is there an elegant method in Mach3?
    Appreciate any feed back
    Apr 2004
    5755
    Re: Beginner dumb question
    If your machine has homing switches, it will establish a "machine home" position that's different from the "floating zeros" that correspond to the origin point of your CAD model. You set the floating zeros after homing the machine, and record the numbers in the DRO before zeroing them out. That way, if something happens and you lose position, you can re-establish it from the machine home. I don't know about Shape3D, but most CAM programs let you change the origin point before generating the G-code, so you can zero the axes in the corner, or in the center, or other places. But once the code is written, all the coordinates are referenced to those zero points.
    Andrew Werby
    Website
    Jun 2022
    Thanks Andrew
  1. My Dumb Question
    By apernell in forum Stepper Motors / Drives
    Last Post: 06-19-2015, 09:13 PM
  2. Maybe a Dumb Question But
    By SPEEDRE in forum DIY CNC Router Table Machines
    Last Post: 05-04-2014, 07:55 PM
  3. Dumb question, but not so dumb??
    By gixxergary in forum Haas Mills
    Last Post: 01-10-2012, 01:30 AM
  4. One Dumb Question
    By Biggermens in forum MetalWork Discussion
    Last Post: 04-11-2007, 09:49 AM
  5. dumb question
    By rob1215 in forum Uncategorised MetalWorking Machines
    Last Post: 06-24-2004, 06:27 PM
