587,300 active members*
3,363 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > New/Old woodworking videos on YouTube
Page 4 of 6 23456
Results 61 to 80 of 101
  1. #61
    Apr 2005
    629
    Re: New/Old woodworking videos on YouTube
    PART 2 of 2
    One of the most useful and used shop projects I have built in my shop is this outfeed table. Even after 15 + years, this is still in constant use in my shop. Initially it was designed as just a large outfeed table. To this day, it is constantly used also as a workbench, an assembly bench, a finishing bench, and of course and outfeed table. This is one of those projects that can MAXIMIZE the space in your shop.
    Please subscribe to the channel, without subscribers the channel cannot survive, IT IS FREE, thank you!
    Resurrected from the Woodworking At Home Magazine.
    Supporting documentation for this video can be found on the companion website. This link will take you to that resource page… https://makingstuffwithchrisdehut.com/woodworking-files
    Cheers!
    Chris DeHut
  2. #62
    Apr 2005
    629
    Turned Tool Handles from the Wood Lathe
    In this video, Dick Sing presents the viewers with the techniques to make custom, handcrafted tool handles on the wood lathe. Don't be content with the standard handles if they don't feel just right, make your own and put your personality into those handles.
    Please visit the companion website for more information about these videos… https://makingstuffwithchrisdehut.com/
    Cheers!
    Chris DeHut
  3. #63
    Apr 2005
    629
    #54 Chest on Frame Cabinet
    This Chest on Frame cabinet is one of those projects that is a must build. This project features: Relief Carving, Joinery, Veneering, Metal Working, Finishing, and the list goes on. Follow along as Chris DeHut walks you through the process and presents plenty of techniques and tips to enhance your woodworking skills.
    Cheers!
    Chris DeHut
  4. #64
    Apr 2005
    629
    In this video, David Reilly demonstrates the process of carving letters. If you have ever wondered about carving letters, this is a must watch video. David shows you how to create the patterns, select the tools, and most importantly, how to perform the actually carving process for the various tools used.
    Cheers!
    Chris DeHut
  5. #65
    Apr 2005
    629
    Learn new skills in joinery. Miter joinery, especially for boxes is especially appealing for its sleek, clean look. The joint, being mostly end grain is week but can be strengthened and its look can be enhanced with the addition of a spline. This jig makes cutting the slots for the spline easy and quick.
    Cheers!
    Chris DeHut
  6. #66
    Apr 2005
    629
    Make this Bench Tool Storage Cabinet for Your Shop
    Having an organized work shop has many benefits, the ability to make more room for tools and make them accessible are just a couple. Follow along in this video as Chris creates a combination storage cabinet and work bench for some of your smaller bench tools. There are plenty of ideas for utilizing every inch of space within the cabinet.
    Cheers!
    Chris DeHut
  7. #67
    Apr 2005
    629
    Relief Carving Q and A with David Reilly
    David Reilly answers some relief carving questions from viewers of the original Woodworking at Home Magazine videos. If you have questions, someone may have asked years ago and the answers might be here for you!
    Cheers!
    Chris DeHut
  8. #68
    Nov 2022
    Thank you for sharing.
  9. #69
    Apr 2005
    629
    Mortise Joinery Fundamentals -- Hand Cutting
    Mortise and Tennon joinery is a staple in woodworking. In this Chris walks you through some examples and techniques for hand cutting mortises. As with all joinery methods in woodworking, one never stops learning how to do it!
    Cheers!
    Chris DeHut
  10. #70
    Apr 2005
    629
    Using Calipers on the Wood Lathe
    Turning accurate or duplicate parts on the wood lathe can seem like a challenge, however, with the right tools and some good instruction, it is certainly achievable! In this video, Dick Sing shows how to use calipers on the wood lathe to get better, more accurate results.
    Cheers!
    Chris DeHut
  11. #71
    Apr 2005
    629
    How to Sharpen Drill Bits on the Bench Grinder
    Drill bits get dull - don't throw them out, sharpen them! There are many expensive jigs and even machines for sharpening drill bits, but you may find they are not needed at all. Chris DeHut shows you how to sharpen drill bits on an ordinary bench grinder. Take the time to learn this skill to save time and money as well as drill more accurate holes.
    Cheers!
    Chris DeHut
  12. #72
    Apr 2005
    629
    Cabinet Door Panels with Relief Carving
    Door Panel Series - Relief Carving. In this video, we will explore the possibilities of carved door panels for use as field panels in cabinet doors. If you are looking for that ultra hand crafted look, it is touch to beat this style! Presented by David Reilly.
    Cheers!
    Chris DeHut
  13. #73
    Apr 2005
    629
    Custom Door Pulls from the Wood Lathe by Dick Sing
    One of the best ways to dress up a cabinet door or drawer is to put a custom pull on it. Dick Sing shows you the techniques and design ideas that will make your cabinets stand out and stand proud! Follow along in this video to learn the techniques to make the pulls. Presented by Dick Sing
    Cheers!
    Chris DeHut
  14. #74
    Apr 2005
    629
    Cabinet Door Panels from Plywood with Applied Trim
    Door Panel Series - Plywood with Applied Trim. In this video we will explore the style of flat, plywood panels for use in the door field. However, this style can be improved by adding some trim pieces that give the panel much more appeal. The use of these trim pieces can also help define the style of the overall cabinet. Presented by Chris DeHut
    Cheers!
    ???????Chris DeHut
  15. #75
    Apr 2005
    629
    Turned Oil Lamps Make Great Gifts
    These turned oil lamps make great gifts and lend themselves to a lot of creativity in design. Dick Sing demonstrated the process of making these lamps and provides some examples to spark your creativity. If you are looking for a new project, this is it!
    Cheers!
    Chris DeHut
  16. #76
    Apr 2005
    629
    Marquetry and Veneered Cabinet Door Panels
    Door Panel Series - Veneered & Marquetry Panels. This video explores a couple of decorative techniques to dress up panels when you need a bit more impact with the design. We will look at Marquetry and Veneer as ways to enhance the look and style of the cabinet doors. Presented by Chris DeHut
    Cheers!
    Chris DeHut
  17. #77
    Apr 2005
    629
    Mortising with a Router
    Continuing the discussion on Mortise and Tennon joinery, this video covers the milling of mortises using a Router with a jig. Fast, easy, and accurate mortises can be milled with a common router.
    Cheers!
    ???????Chris
  18. #78
    Apr 2005
    629
    Turning a Wine Caddy Great Gift Item
    These wine caddies are great gift items and are fun to make. The simple function of them allows for a lot of creativity in their design and style. Dick Sing shows you how to turn them and shows you a variety of styling choices.
    Cheers!
    Chris DeHut
  19. #79
    Apr 2005
    629
    Traditional Frame and Panel Door Construction
    Door Panel Series - Traditional Raised Panel and Frame Construction. After exploring a wide variety of panel design concepts in previous videos, the conclusion to this series is a video on how to make a traditional raised panel cabinet door. This is a great resource to review the process and refine some techniques on the router table. Presented by Chris DeHut Please subscribe to the channel, without subscribers the channel cannot survive, IT IS FREE, thank you!
    https://youtu.be/Fu9gGkzPMsA
    Cheers!
    ???????Chris DeHut
  20. #80
    Apr 2005
    629
    Mortising on the Drill Press
    One of the strongest joints in woodworking is the Mortise and Tennon joint. It has been used for centuries and can me a using a number of techniques. In this video, Chris explores a technique using a drill press and hand tools.
    https://youtu.be/6EHmJAQ3mJA
    Cheers!
    Chris DeHut
Page 4 of 6 23456
  1. Facebook Live Videos on Youtube
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-10-2021, 01:52 PM
  2. Lots of new youtube videos. Thanks Kade!
    By brianbonedoc in forum Smithy
    Last Post: 05-11-2017, 10:22 PM
  3. Motedis Youtube Videos
    By DavidBass in forum Videos
    Last Post: 09-26-2016, 05:05 PM
