Originally Posted by
Cris_co
Update if it helps, I found out how to manually move the magazine and tool change arm, I set them where I could push the pin back and forth, zeroed ma/ts, and still had issues with the ts actual position changing. I ended up removing all the tools from the magazine(12 I believe), then installing them all back in using the 1 cycle start. No issues. The first time I tried to call up a tool in MDI, it stalled out. I removed all the tools and put 5 tools back in using 1 cycle start. Made a program where I cycled those 5 tools in and out several times and had no issues.
Is there some issue that a certain tool could cause? Or is there a problem with the ATC that’s only being triggered by the quantity of tools I had? All my tools are er32 holders, except one 3” face mill, one floating tap head, and a 4” shell mill. The shell mill is large but machine specs a max tool weight of almost 26lbs.
