588,563 active members*
5,266 visitors online*
    May 2009
    1366
    Wire Stripper Tool
    It’s not that I strip wires every day but I have this tool which does a decent job stripping wires from about 18-22 AWG however my problem is stripping the exterior of a cable.
    Don’t know terminology but say I have a cable with 6 conductors inside. My tool can strip each of the 6 conductors but how about stripping the cable without cutting the conductors?
    Is there a tool which does both or I need one for the conductors and one for the cable?
    Nicolas
    Apr 2018
    140
    Re: Wire Stripper Tool
    Depending on the diameter of the cable 'jacket' that you wish to strip, a cheap tool like this can work:
    Attachment 488008
    There is a razor edge embedded in the main plastic bar, below the smaller bar with 'ridges'. The smaller bar is 'sprung' by its plastic hinge, so you push a cable under one of the ridges and rotate the cable.
    I have a couple that came as freebies with a Cat6 (ethernet cable) related purchase. You can see more with a "ethernet cable stripper" search.
    May 2009
    1366
    Thanks for your time, looks like a good solution
    Nicolas
    15362
    They come in all shapes and sizes here is a Pro cable stripper (1) of the many
    Mactec54
  1. Replies: 5
    Last Post: 12-31-2022, 02:36 AM
  2. Wire Frame To Solid 3D Tool Design
    By aldepoalo in forum BobCad-Cam
    Last Post: 05-12-2016, 03:46 PM
  3. How to create an Autozero tool for Z Axis using metal plate and wire
    By guy2b1 in forum Calibration / Measurement
    Last Post: 12-22-2011, 08:27 PM
  4. stripper flash repair alternatives?
    By spock in forum Moldmaking
    Last Post: 04-20-2008, 10:56 PM
