587,250 active members*
3,805 visitors online*
Results 1 to 3 of 3
    Oct 2006
    55
    cnc lathe rough arcs
    I have a prototrak slx1630 that cuts great in x or z but not when working together like when cutting an arc, any ideas why.
    Jan 2013
    474
    Quote Originally Posted by bigbaz View Post
    Check mechanical backlash in each axis, check axis belt tensions.
    Use round nose tool tip.
    Oct 2006
    55
    Re: cnc lathe rough arcs
    Quote Originally Posted by servtech View Post
    Thanks for the reply.
    Oct 2006
    55
    I checked the backlash and reset its bang on, checked axis belt tension and the tool that always worked on my older lathe before this one is a ccgt polished tip with .4mm rad.
    - - - Updated - - -
