588,300 active members*
4,840 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Just ordered the last melon (Torus)
Page 18 of 21 81617181920
Results 341 to 360 of 403
  1. #341
    Oct 2009
    483
    Re: Just ordered the last melon (Torus)
    Quote Originally Posted by CL_MotoTech View Post
    I had to go look at the forum but it appears as though you have to be on 1.2112 for the black and blue screen set. I recommend making the switch. - forum.cncdrive.com • View topic - UCCNC test releases posted in this thread
    CL_MotoTech posted the above on July 31, 2020. I had been running UCCNC 1.2111 which looked like this.
    Attachment 489564
    Tonight I finally got the black and blue screen set up and running when I upgraded to UCCNC 1.2113.
    Attachment 489570
    Note that this super duper UCCNC version is now running on the 240 Volt high voltage monitor (same monitor as before). It is so nice not tripping over the extension cord for the monitor.
    Now all I have to do is relocate the PC Start button and the Main and Drive Power Switches to the front of the mill.
  2. #342
    Jul 2011
    400
    Nice to see some activity on here.
  3. #343
    Oct 2009
    483
    Quote Originally Posted by upnorth View Post
    Thanks. Sorry it has taken so took to respond, but there has been progress in the last two weeks.
    First I had to go through some tools and get them installed in my TTS tool holders. Next up was to measure the Tool Length Offset for each tool.
    Attachment 490168
    I decided to use the table as the place to touch off all of the tools. First I made sure that I had homed the mill, then I slowly lowered the tool until it made contact with the height offset gauge and lit up the red light. This height offset gauge is exactly 2.0000” tall within 2 tenths and has a spring loaded top so tools aren’t damaged from overrun. In .001 increments, it took six jogs in +Z to get the red light to out. My Z backlash has gotten worse than the 0.004” that I measured in 2020.
    Attachment 490170
    Here is the Tool Offset page in UCCNC. I’m not very impressed by the lack of features on the Tool Offset page. Extremely basic functionality.
    Attachment 490172
    And here are four tools measured and input into the table. When each tool had touched off on the height offset gauge, I subtracted 2.000” from the Z machine coordinate shown, and entered that number in the tool table for that tool.
    Attachment 490174
    I quickly realized that I needed a better way to hold and manage all the sharp pokey bits. So I grabbed a scrap piece of 2x4 and used some Forster bits to drill a bunch of 3/4” holes.
    Attachment 490176
    All of my TTS tools finally organized.
    Attachment 490178
  4. #344
    Oct 2009
    483
    Now that I had my four tool length offsets measured and entered into the UCCNC Tool Z Offset table, it was time to find the X, Y, and Z for the G54 Work Coordinate System. I used my Lufkin edge finder to discover the -X and -Y edge of the stock. Since the Fusion 360 CAM had the part origin programmed for the center of the stock, I had to add half of the edge finder diameter plus half of the stock length to set the G54 X offset. Similarly, I added half of the edge finder diameter plus half of the stock width to set the G54 Y offset.
    To set the G54 Z offset, I placed the height offset gauge on top of the part stock and brought Tool #1 down until it made contact. Let's say this value was -8.000". I then subtracted 2.000" from the Machine Coordinate Z shown in order to get from the top of the height offset gauge down to the top of the part stock, so this value is now -10.000". I then added the POSITIVE value of Tool #1 tool length offset (assume this is -13.000") to the -10.000" previously obtained in order to get the G54 Z offset.
    Example: -8.000" - 2.000" + 13.000" = 3.000" G54 Z offset
    This sounds complicated, but it is not too bad in actual practice. This diagram perhaps better illustrates what I'm trying to poorly describe in words.
    Attachment 490746
    The above procedure is easier on the Haas controls that I've used in the past because Haas allows you to add and subtract numbers when using the ENTER key. Unfortunately, UCCNC forced me to do all these calculations on paper and then enter the final number on the G54 table on the OFFSETS tab.
    Shown below is the part drawing and the part shown in Fusion 360.
    Attachment 490748
    Attachment 490750
    This relatively simple part required 11 different CAM operations in Fusion 360. It also used four tools on my mill (and five tools on the Haas TM-1) as I don't yet have a face mill and had to make do with a 3/4" end mill for my facing operation.
  5. #345
    An easy workaround for your math issues is to just use the built in calculator in Windows. My keyboard has a dedicated calculator button, you push it, you have a calculator. It even provides history to your calcs. You do your math, you punch it in the control. But yes, I would agree, a match capable input would be sweet. That said, using a touch probe nearly removes the need for both.
  6. #346
    Oct 2009
    483
    Good to hear from you again, CLM. This is a new to me refurbished Dell laptop that I'm using for Fusion 360 and Solidworks and I never noticed the Calc key. Thanks for that. My mill pc motherboard is still running Windows 7 and I'll have to check if it has the Windows Calculator also.
    I hear you on the touch probe. I have downloaded ProbeIt and hope to get my Drewtronics probe up and running soon.
    After the Face Mill, 2D Adaptive, and 2D Pocket operations.
    Attachment 490756
    After another set of 2D Adaptive and 2D Pocket operations.
    Attachment 490758
    After Spot Drill and Drill operations.
    Attachment 490760
    After Bore, 2D Adaptive, and 2D Contour operations.
    Attachment 490762
    Finished part after Chamfer operation.
    Attachment 490762
    The part on the left was milled on the Torus and the part on the right was milled at school on a Haas TM-2.
    Attachment 490764
    Attachment 490766
    I had made the Fusion 360 CAD and CAM at school for a project. To run it on my mill I changed the Post Processor from Haas NGC to UCCNC. I also changed Tool 1 from a Face Mill to a 3/4" end mill, disabled Tool Changes, slowed the RPM's down from 6000 to 4600, and set up my own tool library.
  7. #347
    Oct 2009
    483
    I had actually run that part from the last post way back on March 5.
    There were quite a few “firsts” accomplished on my little Torus during the milling of that part.
    1. Used the “Black and Blue” UCCNC version 1.2113 for the first time.
    2. Used Fusion 360 to generate the CAM and g-code for the first time. The last part made back in 2020 used SolidWorks CAM.
    3. Used TTS tool holders for the first time.
    4. Used tool length offsets for the first time in UCCNC.
    My next major goal was to get Probing up and running. My Drewtronics probe had been bought in 2020 and it was high time it was put into service. Here is my janky “temporary” connection from 2020.
    Attachment 491494
    I started out with a TIR of 2 to 2.5 thousands. Not too bad for out of the box and who knows how much of that is in the probe as compared to the spindle/R8/TTS ER20 stackup.
    Attachment 491496
    Probe runout is adjusted similar to dialing in a four jaw lathe chuck. I don’t know how, but I managed to get the TIR under 1/4 thousandth (<0.00025”).
    Attachment 491498
    My next step was to download and install ProbeIt for UCCNC from CraftyCNC.com. Eric Brust, who runs CraftYCNC as a one man show, has made it really easy to demo ProbeIt as detailed below.
    This is otherwise a fully functional demo, and may be licensed if you find it useful. Future updates to this plugin will not alter the licensing scheme in anyway, so once a license is purchased, the plugin will continue to work indefinitely, on any PC, without internet connection. The license is tied to your UCCNC controller and SN however.
    I downloaded ProbeIt for UCCNC version 2.200 and got the following error.
    Attachment 491500
    I contacted Eric and he replied that he had forgotten to include some needed files in the download. He suggested that I download and install version 2.201 and that did the trick.
    One of the reasons I went with ProbeIt instead of the UCCNC Probing routines is that ProbeIt has the ability to do probe calibration, unlike UCCNC. Lacking a true ring gauge to use with probe calibration, I used the next best thing.
    Attachment 491502
    I used double sided tape to keep the trailer wheel roller bearing from moving around during the probe calibration routine.
    Attachment 491504
    And into every life must come a little sorrow.
    Attachment 491506
  8. #348
    ouch !
  9. #349
    Oct 2009
    483
    I ordered two new probe tips from Drewtronics and now have them here, but not installed.
    I think my funky way of setting the G54 work coordinate system for the Z-axis bit me in the butt.
  10. #350
    can you add a safe check point in your probing code ? In the code I use I added an m00 at z1" , that way i can visually verify the xy and z are where they should be before hitting cycle start again
  11. #351
    Oct 2009
    483
    Probing code? I don’t have any probing code that I know about. All of my probing to establish the G54 work offsets was done prior to any g-code being run.
  12. #352
    Oct 2009
    483
    After the unfortunate incident involving the Drewtronics probe and the mill vise, I was left wondering whether the damage was limited to the probe stylus (and my pride) or whether I had ruined the entire probe. So I disassembled the probe to see if any internal damage had occurred.
    This picture shows the three legged “flat tripod” still in place inside the probe. The probe stylus is screwed into this flat tripod.
    Attachment 492328
    This shows the arrangement of how the flat tripod and the internal circuitry interact a little more clearly. Each leg of the flat tripod rests on a pair of steel balls that are electrically insulated from each other. At rest each leg of the flat tripod electrically connects one ball to the other. This electrical connection between the balls is interrupted when the probe stylus moves a flat tripod leg off off of the balls.
    Attachment 492330
    Attachment 492332
    The only thing I found wrong inside my probe was that the crash had dislodged the flat tripod from its normal resting place on the three ball pairs. All I had to do to “repair” the probe was to move the flat tripod back to the correct position. I still need to dial in the stylus ruby tip like I did before.
    Here is the probe as good as new with the bent stylus as a momento.
    Attachment 492334
    One last reminder of the mishap.
    Attachment 492336
  13. #353
    Jul 2011
    400
    I also have a Drewtronics probe that was damaged. In my case my toolbox with ball bearing slides and no locks rolled onto it's side. Dumped the probe and broke the carbide ball off the tip of the stylus. I'm quite impressed with the quality of the probe for the price. Good to see it survived with a stylus that bent like that. Before I bought mine I asked if it could be repaired after a major crash. I was told yes and the cost to do so was very reasonable. It would probably be worth keeping a crash kit on hand because it's only a matter of time before I need it.
    Thanks for taking the time to show what is inside the probe. I wondered about it but not enough to take it apart to see. I still need to get some probe tips so I can get mine going again.
  14. #354
    Oct 2009
    483
    That sounds like a bad day when your toolbox tips over. It is interesting that your probe stylus had a carbide ball as compared to the ruby ball on mine.
    I picked up two replacement probe stylus from Drewtronics for only $58 delivered.
    Attachment 492910
    https://drewtronics.org/product/125-...y-ball-stylus/
    These probe stylus look fairly easy to make on a lathe. All you need to do is then epoxy the ball on the end like Drewtronics does. But at only $29 each with free shipping it hardly seems worth the effort.
    Of course I have been lazy and have not gotten around to dialing in the stylus runout and running the probe calibration routine in ProbeIt again.
  15. #355
    Jul 2011
    400
    I might have one of the earlier probes. Maybe that is why it has a carbide ball. The stylus in my case was not bent so I tried to silver solder the ball back on the stylus but that was a complete failure. I do plan on getting a pair of replacements stylus from Drewtronics but it's a little more complicated for me because I live in Canada. He is reluctant to ship here. I have a way to get them here but it takes a bit of time and a little more money. I don't think it's worth making them yourself. They are pretty reasonably priced.
  16. #356
    Oct 2009
    483
    I could buy a pair of stylus and mail them to you?
  17. #357
    Jul 2011
    400
    Thanks for the offer. My sister moved to the USA a few months ago and she is going to do exactly that.
    I was going to edit my last post to say I think there might be a little more to making a stylus than meets the eye. They need to be stiff but not to stiff. They can't deflect but can't be too tough because they may damage the probe during collisions.
  18. #358
    Oct 2009
    483
    I dunno?!? It appears to be made of brass with a small recess drilled in the end to accommodate the ruby ball. You can even see the gray epoxy used to hold the ruby ball in the second picture.
    Your comment caused me to wonder if the shaft was solid or hollow, so I cut the shaft near the end. The shaft looks to be solid except for the ruby ball recess.
    Attachment 492914
    Attachment 492916
  19. #359
    Oct 2009
    483
    I bought an el-cheapo ER20 collet set back in September 2020 for $25 and have used it to set up a half-dozen TTS tools.
    https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
    Attachment 493872
    I’ve come to realize that most of the 14 ER20 sizes are never going to be used. Conversely I’ve found that I ran out of 1/4” and 1/8” collets right out of the gate.
    What are you guys doing to get multiples of the useful ER20 collet sizes?
  20. #360
    Jul 2011
    400
    Not going to like my answer but it's probably cheaper to buy whole sets of collets than to buy individual ones. The sets will be handy for things like drill bits but even with those limited sizes are required. Makes no sense but that seems to be how it is.
  1. Torus Pro vs Torus vs Pulsar vs PM45-CNC
    By Titaniumboy in forum Novakon
    Last Post: 01-28-2014, 06:47 PM
  2. Just Ordered A Torus Pro
    By SCzEngrgGroup in forum Novakon
    Last Post: 10-18-2013, 10:00 AM
  3. Torus Pro Ordered
    By UniqueMachining in forum Novakon
    Last Post: 08-20-2013, 11:13 PM
  4. New Torus Pro Ordered Today
    Last Post: 06-13-2013, 10:51 PM
  5. Ordered a Torus Pro-S yesterday.
    By AUSTINMACHINING in forum Novakon
    Last Post: 05-09-2013, 03:56 PM
