See if this manual matches your manual from the start of all the Parameters P00.00
From what you have posted this manual appears to be the same, if so I can use this to get you going, you have a lot of the main Parameters set so should not take to much to get it going if this manual matches.
I removed this PDF file as it does not match, I'm trying to get the manual from the manufacture.
