587,243 active members*
3,363 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Endmill to cut Gears out of Plywood
    May 2009
    1333
    Making a clock and so have quite a few gears to cut all out of 1/2" thick plywood. I made my toolpath in my CAM and all is good to go but the problem is the endmill.
    Since the teeth are very close together (8”OD gear with 64 teeth) I must use a 1/16” endmill but the cutting end of these endmills is less than 1/2" so I will not be able to cut through the 1/2" plywood.
    Any ideas how to go about it?
    Nicolas
    Dec 2008
    3122
    Re: Endmill to cut Gears out of Plywood
    Just another way to look at making them
    .... turn blanks, include a timing hole with the centre hole. Have gear area stepped in (say 1/8" each side, tooth is 1/4" wide)
    .... place onto a jig to machine the teeth profile
    .... alter root of tooth to allow largest possible cutter, even to drilling the radius before cutting tooth form.
    Nov 2012
    1270
    1.5mm x 15mm endmills are not something unusual. You can buy them cheap on eBay/AliExpress.
    Also, as Superman suggested, you could "tweak" the root of the tooth profile to accomodate a slightly larger endmill.
    Nov 2014
    724
    I had the same challenges for some gears I cut on the CNC and used a 1/4" compression bit to rough the shape followed by a 1/8" bit for the finish cut (1/2" BB material). They came out great.
Name:	013 - 2 sets Enigma cipher gears, dowels, drill guide.jpg
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
