603,369 active members*
3,888 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > SCM Pannel Saw Computer XILIA X915 Rom contents needed.
Results 1 to 5 of 5
    Aug 2016
    6
    Hi, looking for the ROM contents of an old panel saw computer for a SCM Machine.
    The Computer model is XILIA X915, and the pcb board no is TX111A.
    The ROM chips are marked:
    GDT 0979, GDT 0980, GDT 0981
    GDT 0982, GDT 0983, GDT 0984
    If anyone has them please share!
    PS. If someone has the service manual for this machine, or a schematic for the board please let me know.
    Thanks.
    Mar 2007
    13
    Quote Originally Posted by ratmole View Post
    Thanks.
    Huh, I just got an old XILIX X915VC2A PLC from some wood processing machine. In my case there is no any sign of life on CRT. Unfortunately ROM chip labels are different so I can not help you.
    Backup battery dropped to 1.5V so it may be settup is lost but PLC should give some sign of life on CRT no mather of battery. Now whole machine is dead and useless so if someone can help in any way I will appreciate it much.
    Thanks in advance.
    P.S. Machine is SCM P170S wood grinder
    Aug 2024
    Re: SCM Pannel Saw Computer XILIA X915 Rom contents needed.
    I have dump ROM this cnc, if your nead bump Rom please write on my email: [email protected]
    Mar 2025
    282 / 5 000
    Dear forum users
    I am repairing a XILIA X915 controller, The floppy disk starts but cannot read the Disk. (Floppy disk boot read error)
    The floppy disk was replaced, the drive as well, the controller and the ICs around it were replaced...
    Does anyone have any ideas on what else to check?
    Thank you in advance.
    Jun 2025
    Hello, I work and repair this controller, a few month ago. Changing the varta battery and reload the programm ( I have the floppy and process).
    But today new problem : the floppy disk don't work, I hear the motor when start the ontroller, but the drive not recognize and can't see "Disk" in menu. Tje led of the floppy disk not blink. IDE nappe was ok ...
    I search for an idea to... thanks per advance.
    Jun 2025
    Quote Originally Posted by Treasore View Post
    282 / 5 000
    Dear forum users
    Floppy compatible tested :
    Panasonic JU-257A-726P :
    SW1 = DC
    SW2=NC
    SW3=D0
    SW5= PC
    SW6 = M0
    NEC FD1231H
    -Strap #19 controler with #10 IDE
    -R0 on JA1 en position # 2
