587,311 active members*
3,344 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Rotary Joint - Multus B200-W
Results 1 to 13 of 13
    Sep 2011
    104
    Hi group,
    Does anyone know an aftermarket rotary joint to substitute this one
    H0019-0008-28
    ROTARY UNIT
    TYPE: ESX20S-9534Y
    https://www.ebay.com/itm/404172653015
    Mar 2009
    1982
    Re: Rotary Joint - Multus B200-W
    the one with left thread?
    It is bullet proof at Okuma, how it's possible to break it?
    Sep 2011
    104
    Quote Originally Posted by Algirdas View Post
    I bought a used machine an it's leaking at the back of the spindle when I run the through coolant. I was advised it's most likely this part that fails because of some reason - o-rings, scratch on the ceramics because of chips etc
    I spoke with a technician and he came opened the back of the spindle and the rotary joint looked ok. We only changed an o-ring that's in the groove of the other part (not the LH threaded one) and the strange thing is that it seems like it's leaking with toolhlders that have bigger coolant holes and if I out a solid carbide drill and run the through coolant it's not
    Mar 2009
    1982
    smaller hole means higher pressure. The design philosophy is that the pressure delivers sealing. Check the parts where sealing increases with pressure.
    The likely reason can be aold filters at coolant tank - coolant contains some hard particles which scratched the seal surface.
    Sep 2011
    104
    Do you think it could be the seal that sits in the groove or the other one on the LH bolt?
    Mar 2009
    1982
    is the LH bolt surface mirror? By the way it should be graphite.
    I would say replace all relevat plastic sealants.even if the look good
    Jun 2015
    4156
    hy gunda, hy bunny
    i encountered a similar thing a few years ago : the leakage was between pulstud and toolholder, thus the coolant, once inside the toolholer, would go up, between pulstud thread and toolholder thread; to check this, use a blind pulstud, or a normal one, and remove the toolholder, looking for coolant drop on the top ... is tricky, but not impossible
    is a place to look; we swithced to pulstuds with orings / kindly
    Sep 2011
    104
    Seals are rubber, I replaced only the one in the groove on the other part, not the LH bolt because with the mechanic we both decided we'd rather think it over as it was requiring more disassemble.. or we were wrong..?
    Sep 2011
    104
    Quote Originally Posted by deadlykitten View Post
    hy gunda, hy bunny
    Hi Deadlykitten, thanks for joining the discussion.
    Are you referring to the pull studs of the toolhlders or other? This Multus machine has HSK 63
    Mar 2009
    1982
    check if there is no coolant lake at the spindle front ( the tool end )
    Sep 2011
    104
    Can you try explaining with a bit more details so I can better understand where to look at?
    I can send some pics if you can giude based on them
    Mar 2009
    1982
    take the very front cover of the spindle, check if there is collant. Should be dry and shiny.
    or, take the side cover of he spindle, but you need to go from "inside" - to remove samurai.
    Sep 2011
    104
    Thanks Algirdas, I'll do that in a few days and send a pic for a reference when I do
  1. Hurco BMC4020 CTS Hydraulic rotary joint leaking.
    By Shishkinnick in forum HURCO
    Last Post: 11-09-2016, 12:10 AM
  2. Replies: 4
    Last Post: 03-21-2014, 11:13 PM
  3. Anti-backlash rotary joint existance
    By TomB in forum Linear and Rotary Motion
    Last Post: 09-11-2012, 03:53 AM
  4. Wanted-Used Okuma Multus B200
    By MarcvonAmsberg in forum Want To Buy...Need help!
    Last Post: 09-08-2011, 10:22 PM
  5. slip-ring, electric swivel / rotary joint
    By DrStein99 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-10-2006, 01:39 AM
