587,147 active members*
5,682 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Ideas needed: How to mount linear rails to a 2" diameter tube?
Results 1 to 6 of 6
    Nov 2018
    53
    Greetings!
    I have to get this finished. I started this at the start of C19. And I hit a roadblock and it just sits there:-) This is a large scale CNC for clay printing. I am using 2" diameter aluminum I beams.
    I am going to use for the Z axis a 1500mm SBR20 rail. (The base dimensions is 45mm wide with the screw holes 30mm apart)
    I don't have any metal machining access. I do 3D print.
    For my X Gantry I will use 2 HGR20 Linear Guide Rail 20mm wide.
    So I am trying to figure out the best way to mount these to the 50mm diameter round surface.
    Any suggestions?
    Apr 2004
    5740
    Re: Ideas needed: How to mount linear rails to a 2" diameter tube?
    Why not use an aluminum I-beam instead of the round tube? It will have flat surfaces you can mount rails to.
    Andrew Werby
    Website
    Nov 2018
    53
    Well I already have the Ibeam and a 6 foot Truss, about $500. and their tubes are 50mm round. I'm looking for a way to mount these.
    Apr 2004
    5740
    If the truss has two parallel round members you should be able to attach a flat aluminum plate that spans them, and mount your rails to that.
    Andrew Werby
    Website
    Jul 2018
    6457
    Well Disney - Seems you have two directions:
    1) get something thats flat and start again....
    2) print a bracket thats flat to suit the rail and round to suit the truss and screw them together.. good luck Peter
    Nov 2018
    53
    Peter!
    At least for the linear rail, I did design and print some half moons with sockets for the rail. I think that should work for the X axis gantry. Still not sure about the SBR20 . There will be much more force on those. We will see, I don't have the rails yet.
    Thanks!
  1. What to mount linear rails to?
    By ChalkyChalkson in forum Linear and Rotary Motion
    Last Post: 04-03-2022, 09:21 PM
  2. Need large diameter Alum Tube 18 ID x 1" wall
    By mrtbolt64 in forum Want To Buy...Need help!
    Last Post: 04-13-2017, 03:54 PM
  3. Replies: 9
    Last Post: 03-24-2015, 05:55 PM
  4. Minimum diameter for linear rails
    By nekidfrog in forum DIY CNC Router Table Machines
    Last Post: 01-19-2013, 06:07 AM
