I’m doing a circuit on a motorcycle where I need a diode to block the 12vdc from bleeding back and powering up other components. My question is if I twist the cathode leads together then the anode leads together on 4 50v 1amp diodes will this give me a diode that would handle more than 1 amp? Hope this makes sense to the EE’s on here. I cant’ find a diode rated over 1 amp locally and was wonder if this would work. Thanks in advance.
