587,587 active members*
4,658 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Robodrill t14i 4th Axis Installation
Results 1 to 1 of 1
    Apr 2012
    79
    Hi
    Can anyone help me with an installation of a 4th axis on robodrill t14ia please. I have physically installed the drive and motor as per the manual which was quite straight forward and then it instructs to use the Add. Axis Parameter to install it but on mine it is greyed out and I can not use it. Is there something I need to do first to enable this or do I need to manually install it. The manual makes it look easy using this option. Thanks for your time
    Bernie
    Dec 2009
    970
    Re: Robodrill t14i 4th Axis Installation
    Fanuc needs to install the 4th axis option for that to work
    there is nothing you can do without activating the option
