Hello!
I have a Nextech 1530 (I believe to be similar/identical to the Exitech 1530) cnc router with Osai Software.
I'm having a lot of trouble to home the machine. It returns an overtravel error on the x-axis. During homing, intially the procedure goes normally. The Y and Z axes get initialised sucessfully.
The X axis hits the home switch, reverses all the way back to the other side of the table, triggers the limit switch and raises the overtravel error (042: Axis on over travel limit).
Some tests I've made:
- All inputs (limit switches and home switch) trigger correctly and in correct order.
- We tested triggering manually the switches before they get to the home position, we get the same result.
This problem persists for more than a month now, various technicians tried to diagnose it, but no progress was made.
Any help will be greatly appreciated by this point.
Thank you!
