Ok, I just found it... ( it was in the common section in the parameters on the second page down the list )
When I turned mine to a "!" it allowed it, but it has a "T" behind it, so I'm assuming this is a Trial?
After I turned the macros on, I tried to go into my offsets but I'm not seeing the probing options like you normally see.
Is this because I don't have the hardware actually hooked up ( probe and tool setter ) ?
Thanks,
Kent
