Thank you phucrobusl and memoryman very much. Received Base0 board after vacation, changed it and system booted. Only had blown transformer, two automatic fuses and one servo... Now there left to repair the servo
Hello again, maybe someone has Fanuc servo amplifier schematic/service manual? Board A20B-1003-0090/2. As I understand there is a problem with DC voltage detection after shortening of phases in transformer. DC error Even at much lower supply voltage braking resistor is often turned ON and overheating switching transistor. Suspecting DV46.
Regards
Romas
i have alarm problem Murata c3000
1013 IN PUNCH CYCLE
P.m me [email protected]
merhaba elimde kıtamura my center 2 1984 model makinam bulunuyor kontrol sistemi fanuc system 6m bana bu makianın kullanım kılavuzu kitapçığı gerekli elinizde mevcut ise [email protected] adresime gönderebilirseniz sevinirimn iyi çalışmalar
i search for manual or eschematic A06B-6055-h208 or similar ... thks [email protected]
Hello all,
Maybe someone has maintenance manual for Fanuc 15T? Especially for led indications on Base0 board A16B-2200-0121 and other boards. Mail [email protected]
I need fanuc 15A connection and maintenance manual.can you send me please?please please ???? ???? ????
[email protected]
how is Robocut Alpha OB operator amd/or alarm manuals?
