I`m having problems with the turret rotation.
When running a program recently the Tool call for station 1 resulted in the turret rotating into position but not locking into place, I`d receive a timeout error and the program would stop. If I then went into jog mode and rotated the turret manually once, then go back to program and restart on Tool 1 it would rotate and run ok.
This also happened on Tool 10..
At times even calling Tool 1 or 10 under MDI would also result in the turret not locking into place.
Occasionally using the Jog mode the turret would not stop spinning !!
We had a service tech in but has not found the problem. He went off trying to find if there are any parameters that could be altered, his thinking being that as the machine is only a couple of months old, perhaps the turret positioning sensor is set too fine and he`d like to try relax the tolerances within the parameters before stripping the machine to look for mechanical problems.
Can anyone offer any help on this please.
Another question I have is the driven tooling mechanism.
I was using a single flute boring bar for a tight tolerance hole and needed to rotate the tool in order to set the size using a clock gauge, but there is no way I can find to disengage/turn off the drive.
Thanks for any advice
