LAN5160T4 Ethernet CNC 2in1 Integrated 4 Axis Mach3 Motion Controller & Stepper Drivers 300KHz 6A Support Standard MPG & NVMPG
- Support EtherNET;
- 7 ports input interface for ordinary digital data;
- 3 ports output interface for ordinary digital data;
- 1 port 0-10V spindle speed analog output interface(can change to PWM output);
- can support 4 axis stepper systems,300KHz pulse output for every axis;
- ARM motion control chip;
- Compatible with MPG input, support standard MPG & the digital display MPG of our company.
- Each axis driver supports 256 subdivisions at most.
- Each axis driver supports 6A current The static current, running current and subdivision of the driver can be adjusted.
- The adjustment position is on the plug-in page of mach3
LAN5160T4
https://www.aliexpress.com/item/3256804613672038.html
MPG
https://www.aliexpress.com/item/2255800599512044.html
