603,333 active members*
3,381 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Old Roland Gravograph Unica rebuild
    Sep 2021
    11
    Hello!
    I have an old Roland Gravograph Unica engraving machine and I would like to rebuild it to use Mach3 software. There is in use three 1.8 Deg DC 0,8A Stepper motors. What controller and breakout board would you recommend? Should I change the old stepper motors to Nema 17? AliExpress sells closed loop stepper motor driver controllers but they are meant to be arduino. I would prefer some other breakout boards what designed for Mach3. Maybe someone can recommend a good 3 axis cnc kit.
    Thank You!
    Apr 2022
    148
    Re: Old Roland Gravograph Unica rebuild
    How many wires come out of the stepper motors?
    Sep 2021
    11
    6 wires.
    Nov 2013
    5404
    Sanyo-Denki is a very good name in steppers. With six wires it sounds like they are unipolar which restricts your choice of driver somewhat, most readily available drivers are bipolar.
    If you do replace the steppers get low inductance steppers. At 17 size ideally less than 1mH. High torque is nice, but high torque often and usually means high inductance.....and you do
    not want those. Better off with medium torque but low, even super low inductance.
    Mach3 is obsolete. All development ceased eight years ago. If this is a new build then get Mach4. I have been using Mach4 and an Ethernet SmoothStepper for eight years. There are other choices.
    https://www.cnczone.com/forums/deskc...-software.html
    Craig
  1. Gravograph VX Upgrade/Rebuild
    By Dec0y in forum Engraving Machines
    Last Post: 12-31-2022, 11:52 PM
  2. Replies: 0
    Last Post: 05-30-2021, 04:22 PM
  3. Replies: 1
    Last Post: 12-29-2018, 05:37 PM
  4. Vanguard Unica
    By lostbaka in forum Engraving Machines
    Last Post: 11-01-2011, 10:34 PM
