I think you are misunderstanding how Home switches work.
When homing the machine will move in the programmed direction at the programmed speed UNTIL it encounters the Home switch, whereon it decelerates to a stop and then backs up UNTIL
the switch deactivates. The axis is Homed when the switch deactivates not when it activates. So the accuracy or repeatability is not how much the switch travels before activation, but how
repeatable the hysteresis is, ie the travel until the switch deactivates.
So your Metrol switches might be best if you need to precisely define an edge or similar, and that I would call absolute positioning, but for repeatable homing then a switch with defined and repeatable
hysteresis is what you want. Such a switch might cause the axis to define Home as 0.435mm from the switch activation point but because it has defined hysteresis it will be 0.435mm plus or minus 0.01mm every time.
the absolute position is not that critical, but having a repeatable switch deactivation point is critical.
Craig
