587,238 active members*
3,806 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Can this tool be used in an ER collet?
Results 1 to 11 of 11
    Apr 2017
    26
    Hello, I just got this new carbide keyseat cutter and I’m a little stumped as to whether or not I can put it in an ER32 tool holder. There is a large flat running down the entire length of the shank. Unfortunately I didn’t notice this large flat when I ordered it. I was in too much of a hurry and just completely overlooked it.
    My question is can I use this in an ER holder or do I need a set screw holder only? Right now I have a HSS cutter in an ER32 holder that this one will replace. I would like to use the same holder but worried that area will not hold it securely, or hold it slightly off center, and/or collapse the collet in that area. At this time I do not have a set screw holder to hold it. Need to get one…
    1/2” shank, 1/2” diameter, 1/16” cutter width.
    Flat measures about a 1/4” wide across the flat
    Thanks!
    Nov 2013
    4491
    Re: Can this tool be used in an ER collet?
    is it going to do any harm to try it?. Its either take it back for a refund, if that's possible, or take a gamble and try it.
    Craig
    Apr 2017
    26
    Craig
    True, probably just overthinking it, I have a bad habit of that. Was worried about screwing up the part or the cutter or both. Figured I’d ask first. Thought at least one person on here may have faced the same thing and would know instantly if it’s a good idea or not. Not sure about the refund, I’d have to check. Thanks!
    Nov 2013
    4491
    I've used tools with a Weldon flat in ER collets without problem. The Weldon flat is not the full length of the shank though.
    I suspect if the flat is small relative to the overall diameter of the shank the ER collet will grip it OK. If the flat is to large then the collet will distort out-of-round before
    it exerts enough pressure to clamp the tool.
    Craig
    that small of a flat will be fine in an er32 , and probably safer than using a side lock the way it is . A flat like that is silly and prone to slipping in a side lock , they should have cut a weldon or nothing
    Some people would be concerned with distorting the collet but I've yet to see that happen
    Jun 2015
    4156
    hy is ok, use the collet
    such tools, if to be integral, are better of hss, rapid steel
    if from carbide, then there are indexable versions, where only the tip is changed, and the shank remains ... should be les$ss$$$s$$ / kindly
    Apr 2017
    26
    Craig
    Thanks. I’ve done the same, Weldon flats in an ER collet. But this one surprised me. Never really seen a Weldon flat run the whole length. Reminded me of some boring bars.
    Apr 2017
    26
    Quote Originally Posted by metalmayhem View Post
    Makes sense that a larger beefier collet, with a smaller diameter tool compared to it, might not affect it. Worse in say an ER20 because it would be at its max, thinning out the collet? Seems logical. Thanks
    Apr 2017
    26
    Quote Originally Posted by deadlykitten View Post
    Thank you. I’ve used only used HSS when it comes to keyseat cutters. First time with a carbide keyseat cutter. I assumed going carbide may be better, cut faster, cut cleaner, less burrs, last longer? It will be used for various material, currently to be used on 4140 annealed and then quite possibly 4140 heat treat after. Mainly got it for the heat treat material. I like the idea of indexable ones but I haven’t looked into them at all.
    Jun 2015
    4156
    today i bumped into iscar 5607342 for some setup somewhere, and i aslo mentioned it to you
    check also attached
    so far i used 2 versions :
    ... big diameter, with separate inserts, like any regular toolholder
    ... tiny diameter, not with inserts, but with full interchangeable head
    both worked, etc .... anyway, i am not here to sell iscar / kindly
    Apr 2017
    26
    check also attached
    Oh wow, very interesting, thanks! I’ll have to look into those. Mine will be used for the side slotting that it shows on there. Thanks again, didn’t know these existed
  1. idea for faster er collet tool changes
    By QuinnSjoblom in forum MetalWork Discussion
    Last Post: 06-21-2018, 07:52 PM
  2. Tool changer collet lock?????
    By R.DesJardin in forum Tormach Personal CNC Mill
    Last Post: 02-05-2009, 06:27 PM
  3. ER-16 Collet stuck in ER-16 Tool Holder
    By JWB_Machining in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2008, 08:04 PM
  4. Cat 40 collet tool holder question
    By dlenardu in forum MetalWork Discussion
    Last Post: 03-20-2008, 08:26 PM
  5. R8 Collet Holder Tool Setter
    By Chrisjh in forum Syil Products
    Last Post: 08-07-2007, 02:44 AM
