588,205 active members*
4,489 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport Interact 412V/151 control Parameters year 1986.
Page 1 of 2 12
Results 1 to 20 of 21
    Jan 2011
    30
    I just bought a 412V with a heidenhain 151 control, built in 1986 with a 6000rpm spindle. The batteries were dead, so I replaced them and then tried several different parameter lists, with no success. Can anyone help me out? 236 parameters, I don't know how to look up what variant/software/ etc.
    Jan 2011
    30
    Re: Bridgeport Interact 412V/151 control Parameters year 1986.
    Okay, I think I found a good set of parameteres, but here's where things get crappy. I write them all in, but can't get past DC Relay Voltage Missing. On next start up, the parameters are gone again. I replaced the batteries with known new AA cells. Is it time for a retrofit?
    Jan 2011
    30
    Okay, definitely leaning towards a retrofit. I now need wiring diagrams for this thing. Anyone have diagrams for a 412 with TNC151?
    Aug 2009
    1573
    ...retrofit sounds good but, is a big step. Most times never gets finished and sits in the corner of the garage collecting dust on top of the pool table.. Let's see if we can fix your current setup.....I see you said there was error code of a Voltage problem....have you tested all the Power Supplies? 5vdc, +12., -12vdc, etc?
    DJ
    Jan 2011
    30
    DJ
    24 v power supply (only non-ac supply I see) is pumping along at 24v. I need diagrams to go any further
    Aug 2009
    1573
    Quote Originally Posted by B.Reilly View Post
    ...here's a 151 service manual I found for a start. The 412 looks a little more harder to find,so far.
    https://product.heidenhain.de/JPBC/i...33_00_a_02.pdf
    Jan 2011
    30
    Thank you, I have found the 151 manual before, but it just doesn't have enough info unfortunately. The 412 has proven to be nigh impossible to find. I'm now hitting up paid tech support places to try to find one....
    Jan 2011
    30
    I've ordered a maintenance manual from BPTParts.com, so hopefully I'll have something to go off of next week.
    Aug 2009
    1573
    ...oh, Textron has some support for the machine. That's good news. I was looking thru that Heidenhain manual and saw on page18 some Test Points just in case you miss it.
    Jan 2011
    30
    Manuals have arrived! Looks like my PC100 (PLC) board is non-functional. It has 24V in, it has the E-Stop signal, and it is not enabling CR2, to start the machine.
    Jan 2011
    30
    Attached is the wiring diagram I have for this machine.... it seems to me that if 2CR isn't energized, the machine will not be able to turn on. I was wrong earlier, it doesn't appear that the E-STOP voltage is reaching the PC100 board.Attachment 498990
    Aug 2009
    1573
    ...hard to read that attached diagram. Maybe try pdf type file.
    Jan 2011
    30
    Lets try this.
    Attached Files Attached Files
    Aug 2009
    1573
    Lets try this.
    ...much better and very readable when zooming in. Have you checked the Limit Switches on each Axis? They maybe are not functioning correctly.
    Jan 2011
    30
    I have bypassed the limit switches by applying power directly to J4/3 and I get the same result - 2CR and 1 CR will not turn on (nothing changes). I can turn on both by applying power directly to J7/1 for 1CR and J3/10 for 2CR. The control still displays the same error and does not respond. I'm suspect of the PLC board all together.
    Aug 2009
    1573
    ...is this machine wired for 4th Axis? ....I see an Input to PC100 marked "4th fitted"... may need a dummy Plug if, no 4th is present.
    Jan 2011
    30
    No 4th axis, and according to the previous owner, has never had a 4th axis.
    Dec 2023
    3
    Buen día
    Alguien tendrá el software para eztrack 3 ejes
    Aug 2009
    1573
    ....it doesn't appear that the E-STOP voltage is reaching the PC100 board.
    could this be a Parameter setting or bios? but, the issue of E Stop string not being completed for your machine sounds more likely the problem not the PC100 hopefully. The Axis amp's would be another possible thing to check they are sending a clear to enable signal to the PC100
    DJ
    Nov 2008
    69
    I have a lot of experience with the HEIDENHAIN controls. Old and new ones too.
    When you change the batteries you need to clean the contacts with sandpaper before you put in the new ones.
    Happened to me too and not only once.
    Jukka
Page 1 of 2 12
  1. Bridgeport Interact 412 W/ Heidenhain 151 control
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 06-06-2017, 01:22 PM
  2. DWC110-H year made 1986 with a W7 control
    By LIVEWIREEDM in forum EDM Discussion General Topics
    Last Post: 08-02-2014, 07:51 PM
  3. Replies: 3
    Last Post: 12-06-2011, 12:06 AM
  4. Bridgeport interact 412V
    By jovanov in forum Bridgeport / Hardinge Mills
    Last Post: 05-10-2011, 12:43 AM
  5. Replies: 6
    Last Post: 05-27-2008, 02:55 PM
