587,558 active members*
3,664 visitors online*
Results 1 to 10 of 10
    Aug 2007
    51
    Fanuc SRAM Backup Stuck
    I have 3 Nakamura Tome WT250 lathes, twin spindle, twin turret, Fanuc 18i TB control.
    I made SRAM backups for the machines. For 2 of them, the backup works ok, it writes 4 files for every machine (SRAM2_0A, SRAM2_0B, SRAM2_0C, SRAM2_0D). I even had to restore a SRAM backup once and it worked fine.
    BUT on one of the machines, when i try to make the backup, it writes the first 2 files on the card and then hangs at the 3rd file and does nothing. It just stays stuck there. If i remove the card, i have only the 2 files that were completed.
    Any idea why this happens and how to solve it?
    Thnaks.
    Dec 2009
    970
    Re: Fanuc SRAM Backup Stuck
    On the machine that you want to try the sram and is not loading all 4 files,did you tried to take out the sram?
    Even if the machine is not starting you can take out the old sram to see if it is split also in 4 files
    The Sram files are different split depending on the SRAM pcb capabilities ,even you have the same controller 18i-TB
    can ypu post the serial numebr of each cnc ,is the code with EXXXXXXX on the back of the cnc located on the back of the screen
    Aug 2007
    51
    Thank you for taking time to help.
    The machine works fine, so i wouldn't want to work with the SRAM and risk loosing parameters and making the machine unusable. I just want to make an SRAM backup and not mess anything up.
    My problem is NOT with restoring SRAM, but with the backup hf the SRAM. It only saves 2 files on the card, instead of 4, and on the screen it says "COMPLETE" for thebfirst 2 files and stays stuck at the third file.
    I will send you serial numbers tomorrow.
    Feb 2024
    17
    I'm in the same scenario
    We have three almost identical Star SV32 Lathes with Fanuc 16i Contols
    One of them writes one out of two files then halts indefinitely exactly as you describe
    Showed the phenomenon to our Star supplier's tech who basically went ¯\_(?)_/¯ and told me to just give it more time. Think i had it chugging for three hours before i gave up
    Apr 2009
    1379
    All parameters and other data, other than part programs, are stored in the first file. Only if the first 512k of sram is insufficient, will additional files have programs in them. So, don't be too concerned.
    Apr 2009
    108
    There may be a difference in the memory size. Take a look at the memory size in the program directory and compare the machines.
    Apr 2009
    1379
    But it should indicate completion of backup regardless.
    Apr 2009
    108
    Quote Originally Posted by memoryman View Post
    You are correct. It sounds like a corrupted memory area. As you mentioned earlier, the information should be stored in the first one or two files. You can try downloading a blank file from Memex at the link below and rename it to the missing files. This should work. Although, I would still be concerned as to why it failed.
    https://www.memex.ca/support/downloads/
    I like the SRAM backup for its simplicity. I would also recommend making a text file backup using a memory card. This will allow you to view the files. It doesn't hurt to have both. I made some videos a few years ago on how to backup a machine. They're for the 32i, but it should be close. They don't cover everything, but it's a good start. The 18i does not have the all data backup option.
    Programs, offsets, macro, all data
    [URL] https://www.youtube.com/watch?v=L0Orppljfy8&t=32s
    Parameters and PMC data
    [URL] https://www.youtube.com/watch?v=aM_jW2hkO_E
    SRAM
    [URL] https://www.youtube.com/watch?v=dXKE6s_dzSE
    Apr 2009
    1379
    Also available from [email protected] (I supplied the 'empty' files to Memex...)
    Aug 2007
    51
    I thought that since my machine is Twin Spindle, it works like 2 machines in one, so the first 2 files would be for one machine, and the other 2 files would be for the other machine. I didn't get this information from somewhere, it's just what i thought. If indeed all parameters and data is in the first file, then i should be fine.
    Anyway, since i have other 2 identical machines in my shop, i'm kind of relying on the SRAM files from the other machines to help me if i ever need an SRAM restore. They might work with slight adjustments after the restore. But still, if i find a way to fix this issue and manage to backup this SRAM, it would be better.
  1. Fanuc 16iA, SRAM Memory Card Backup
    By mflux_gamblej in forum Fanuc
    Last Post: 03-12-2024, 09:02 AM
  2. fanuc oi tf from flashed no sram backup
    By phucrobusl in forum Fanuc
    Last Post: 10-22-2019, 05:57 PM
  3. Fanuc oi-td total SRAM backup
    By firstName in forum Fanuc
    Last Post: 07-30-2018, 08:40 PM
  4. Replies: 4
    Last Post: 07-12-2012, 08:34 AM
  5. Replies: 0
    Last Post: 07-22-2010, 02:03 PM
