Found some torque specs and manual. The drawbar has a philips head screw and a 7/16 hex. The recommendation is to use the philips drive to tighten to avoid over torque. It says the hex is ok but limit torque to 25 in-lbs. I find it much easier and more controllable to use the hex. Guess I need to find a cheap torque wrench for this range.
