587,157 active members*
3,741 visitors online*
    Mar 2018
    3
    CNC 6040 - issue with working
    Hello,
    I have 6040 CNC machine 2.2kw with 4 axsis. Every gcodes I'm making in UCanCam program. After calibrating I have some issues like:
    1. Cutiing not in one line, like on the photo:
    2. Sometimes cutting in material like this:
    3. Not making circle:
    Any ideas? Or some has same problem? Maybe it is problem with controller?
    Apr 2004
    5740
    Re: CNC 6040 - issue with working
    I'd look for mechanical issues first, like a coupler or pulley that's slipping or a bearing that's loose. If you can't find anything like that, try reducing the acceleration on any axis that's not performing correctly.
    Andrew Werby
    Website
    Dec 2003
    1234
    A picture of the machine might have been useful.One way of learning more is to run the same sequences in the opposite direction and to compare the results.I would be surprised if it is the controller and it might help us if we knew what depth of cut,spindle speed and feed rate you were using.I agree with awerby that a mechanical issue is the first thing to look for and it would only take something like a bolt vibrating loose to cause problems.
    Mar 2018
    3
    It is Chinese 6040 2.2kW. This most popular.
  1. 6040 CNC controller/spindle issue
    By dbaker11345 in forum Chinese Machines
    Last Post: 09-10-2021, 11:05 PM
  2. Newbie to CNC issue with chinacnczone 6040 spindle
    By Iron_Geek_37 in forum Chinese Machines
    Last Post: 04-21-2020, 09:16 AM
  3. CNC 6040 Setting or Other Issue - HELP!
    By DeeMaster in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2016, 11:16 AM
  4. Z Probe issue - 6040-S80 Carving-CNC
    By halebopp76 in forum Chinese Machines
    Last Post: 07-18-2013, 11:00 AM
  5. Need Help With 6040 CNC Coolant Issue
    By EvoMan001 in forum Australia, New Zealand Club House
    Last Post: 05-27-2013, 10:32 AM
