Re: Toroidal Transformer hookup
Surely you have the manual for the drives that show the hook up? see attached.
It states 24VDC to 70VDC (typical 36vdc) You will require a bridge rectifier after the Toroidal. The rectified and smoothed DC is x1.4 the AC .
The advantage with a Toroidal is that it can easily be modified by either removing or adding secondary turns
Albert E.
