588,225 active members*
4,883 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > High pitch sound from ac servo
Results 1 to 5 of 5
    Dec 2017
    16
    Hi all, my stepperonline T6 ac servo has been making weird high pitch sound. This sound is not affecting the performance of the servo but it is really annoying. I have contacted stepperonline who claims the sound is normal. However, I doubt their claim. Anyone knows how to get rid of this sound?
    https://youtu.be/wuxcFftns08
    Jan 2008
    1543
    Re: High pitch sound from ac servo
    Did it make the sound from new? Have you tried altering the tuning at all?
    Nov 2013
    4603
    I suspect that it is caused by the rotor dithering.
    lets say the servo is commanded to position 123456. The servo drives to that location but overshoots to 123457, so it tries to back up and overshoots again to 123455.
    The it will drive forward....and keep repeating this little cycle. It called servo dither.
    Most AC servo software has a parameter that describes a 'Zero Error Zone', that is to say a small band that if the commanded position is within so many encoder counts of the
    actual encoder position it declares 'this is good enough' and stops trying to get any closer. Different manufacturer call it different things but the idea is the same. Find that parameter and program it
    to be wider.
    Craig
    Feb 2007
    969
    Try lowering your Gain settings in the PID . Kp and Kd a bit
    Do you know if it made that noise before you tuned it.. of did you tune it ?
    Larry Kenny
    www.LarkenCNC.com
    email : [email protected]
    Viperservo.com ( may have issues , so use LarkenCNC.com )
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Dec 2017
    16
    Yes. it has been this way since I got it. I have already tuned the relevant parameters.
    - - - Updated - - -
    Quote Originally Posted by Larken View Post
    Larry Kenny
    www.LarkenCNC.com
    It has this way before and after tuning.
    - - - Updated - - -
    to be wider.
    Craig
    Thanks Craig. I will do that.
  1. Constant High Pitch Sound From Only One Stepper Motor
    By TannerFrisby in forum DIY CNC Router Table Machines
    Last Post: 09-03-2020, 04:20 PM
  2. Help Please - Stepper motor high pitch noise
    By fEkuaR in forum Stepper Motors / Drives
    Last Post: 06-30-2017, 08:03 PM
  3. fADALVMC 4020 High pitch squeal
    By awjjim in forum Fadal
    Last Post: 06-04-2013, 02:53 AM
  4. high pitch sound
    By ramsey321 in forum Tree
    Last Post: 10-29-2010, 08:25 PM
  5. Stepper-High Pitch/Frequency Noise
    By azt34 in forum Stepper Motors / Drives
    Last Post: 05-19-2006, 01:41 AM
