588,227 active members*
4,535 visitors online*
Page 2 of 8 1234
Results 21 to 40 of 142
  1. #21
    Oct 2009
    867
    Re: A Desktop CNC by David A
    Repeat on remaining stringers.
    Attachment 505034
    Attachment 505036
    Attachment 505038
  2. #22
    Oct 2009
    867
    Slide top profile over the braces.
  3. #23
    Oct 2009
    867
    And align with the front face of the upright.
  4. #24
    Oct 2009
    867
    Top profile should be level but check anyway.
  5. #25
    Oct 2009
    867
    Next is the installation of the side plate.
  6. #26
    Oct 2009
    867
    Side plate locks everything in place.
  7. #27
    Oct 2009
    867
    And finally, install the vibration dampers.
  8. #28
    Jul 2018
    6524
    Looking solid David - Peter
  9. #29
    Oct 2009
    867
    Thanks Peter. Much appreciated....
  10. #30
    Oct 2009
    867
    Repeat all steps for the other side of the stringers.
  11. #31
    Oct 2009
    867
    Install splash screen guides.
  12. #32
    Oct 2009
    867
    And finally, slide the splash screens into place.
    Color added to splash screens for clarification.
    Frame is shown from the back
    Attachment 505296
  13. #33
    Oct 2009
    867
    This concludes the assembly of the machine frame.
    It can accommodate different personal designs for the gantry and the Z-axis
    and is available for purchase as a complete set as shown on this thread for:
    In 2 x 2 size: $1,875
    In 2 x 3 size: $1,950
    In 2 x 4 size: $2,100
    You can email any questions you might have to: [email protected]
  14. #34
    Oct 2009
    867
    Machine frame is finished.
    Thread continues with the design for the Y/A and the X/Z axis.
    Install linear rails to the top profile.
  15. #35
    Oct 2009
    867
    The Y/A carriages.
  16. #36
    Oct 2009
    867
    And the gantry beam.
  17. #37
    Oct 2009
    867
    Install the front bumper stops / ball screw clamps.
  18. #38
    Oct 2009
    867
    And the rear bumper stops / ball screw supports.
  19. #39
    Oct 2009
    867
    Gantry installed.
  20. #40
    Oct 2009
    867
    Rotating ball nut drives.
    As the ball screw does not rotate, a 1204 size is used.
    Motor size: Nema 23
    Lead: 4mm per revolution
    Speed: 157 inch/minute @ 1,000 RPM
    Dynamic/static rating: about 600lbs/1,000lbs per screw
    Max. speed: 3,000 RPM
    Attachment 505372
Page 2 of 8 1234
  1. David A's Benchtop CNC Version 2
    By davida1234 in forum DIY CNC Router Table Machines
    Last Post: 09-09-2021, 02:08 PM
  2. Replies: 0
    Last Post: 06-06-2018, 01:50 PM
  3. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum For Sale Only
    Last Post: 09-18-2015, 09:05 PM
  4. KL-6090 Desktop Cnc Router desktop,(24 x 36 x 6 inch)
    By automationtechinc in forum News Announcements
    Last Post: 04-28-2015, 11:23 AM
  5. DIY David Steel CNC
    By Wineryrjd in forum DIY CNC Router Table Machines
    Last Post: 03-28-2010, 01:39 PM
