ESPRIT postprocessor ONA AD25/AD35
hi guys
in need tested and working post processor for ONA AD35 / AD25
I currently own a machine and have a strange problem with my postprocessor under esprit.
the programs for cutting cones and 2d cutting works the programs are correct
the problem occurs when i try cutting in 4 axes
example program - punch - square at the bottom circle at the top, both have a diameter of 10mm, 50mm high detail
https://www.youtube.com/watch?v=TwSi9pDkm18&t=240s
https://www.youtube.com/watch?v=czSdtJ40dSQ
in esprit everything is OK simulation looks OK cuts what and how it wants same as on this two movies
however after saving with my postprocessor to the machine the program is wrong - either I have the wrong shape or the machine cuts the shape of a square at the bottom and top with the difference that the top one is only twisted by 2 degrees in relation to the bottom one
maybe someone have postprocessor to compare ? or have a solution for that case
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
