Repeat on remaining stringers.
Attachment 505034
Attachment 505036
Attachment 505038
Attachment 505034
Attachment 505036
Attachment 505038
Looking solid David - Peter
Thanks Peter. Much appreciated....
And finally, slide the splash screens into place.
Color added to splash screens for clarification.
Frame is shown from the back
Attachment 505296
This concludes the assembly of the machine frame.
It can accommodate different personal designs for the gantry and the Z-axis
and is available for purchase as a complete set as shown on this thread for:
In 2 x 2 size: $1,875
In 2 x 3 size: $1,950
In 2 x 4 size: $2,100
You can email any questions you might have to: [email protected]
Rotating ball nut drives.
As the ball screw does not rotate, a 1204 size is used.
Motor size: Nema 23
Lead: 4mm per revolution
Speed: 157 inch/minute @ 1,000 RPM
Dynamic/static rating: about 600lbs/1,000lbs per screw
Max. speed: 3,000 RPM
Attachment 505372
