Originally Posted by
stabbiex
Hi!
I have a tool change issue with my 1989 Bridgeport Interact 412, TNC2500. When machine is started, the first M06 procedure runs correctly, the turret is turning without any problem.
When I run M06 for the second time, the cycle doesn't finish.
This is what happens:
1. Z axis moves to the top position
2. Spindle doesn't rotate to home position (I hear just a click noise)
3. Z axis goes down to tool change position
4. Machine stops, no error, only shows blinking * symbol
Sometimes in step 2 the spindle just rotates tiny bit and directly moves to step 3. Seems to be a random thing.
At the same time the M19 works perfectly fine.
I tried running a program with tool call function as below. Same situation as with M06 in manual mode. Sometimes it worked and it performed full tool change cycle, but then the second tool change will get stuck in same way as described before with M06 in manual mode.
BEGIN PGM 1001 MM
TOOL DEF 1 L0 R+0.5
TOOL CALL 1 Z S2160
R F M06
The machine was working just fine in the beginning. Then it was stored for two months and moved to a new location.
Any help will be appreciated!
