587,997 active members*
2,014 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > IF statement returns unexpected value
Results 1 to 13 of 13
    Nov 2009
    17
    Question IF statement returns unexpected value
    I have a parameter _L2R, set to either 1 or 0.
    (txt,L2Rtxt,Neither)
    (print,$<L2Rtxt>)
    (print,#<_L2R>)
    if [#<_L2R> EQ 1] then (txt,L2Rtxt,Yes)
    if [#<_L2R> EQ 0] then (txt,L2Rtxt,No)
    (print,#<_L2R>)
    (print,$<L2Rtxt>)
    displays the following:
    Neither
    No
    So the L2Rtxt parameter is being set correctly to "Neither" originally; _L2R is set to 1 originally.
    The first if statement should then set L2Rtxt to "Yes"
    The second if statement should not do anything...but it's setting L2Rtxt to "No"
    Why?
    Mar 2017
    1333
    Re: IF statement returns unexpected value
    IF..THEN was never designed to do this but I can fix it.
    You could also use Oword.
    Nov 2009
    17
    Yes - if you fix it, can we also add the ELSE option?
    if [#<_L2R>] then (txt,L2Rtxt,Yes) else (txt,L2Rtxt,No)
    Mar 2017
    1333
    Nov 2009
    17
    This will be in next version, correct?
    Mar 2017
    1333
    Yes, beta version will be published in few days here:
    https://cnc.zone/tng/tng
    I just need to finish all parameters testing:
    https://cnc.zone/tng/parameters/parameters
    Nov 2009
    17
    Thank you!
    Mar 2017
    1333
    This will also be an option in new version:
    https://cnc.zone/gcode/functions/func-strappend
    Nov 2009
    17
    Did the new version get released and I just can't find it?
    Mar 2017
    1333
    Beta version is available here:
    https://test.planet-cnc.com/download.html
    Nov 2009
    17
    When I go to that link, I just get "PlanetCNC TNG version check"
    Mar 2017
    1333
    Nov 2009
    17
    The only beta version is windows? I can work with that, but if you have a raspberry pi version, that would be better.
  1. Ball screw returns
    By crazybrit in forum BallScrew Repair
    Last Post: 02-20-2023, 02:37 PM
  2. Planet CNC returns
    By PhillS in forum PlanetCNC
    Last Post: 12-10-2019, 03:19 PM
  3. Alibre returns?
    By MichaelHenry in forum Uncategorised CAD Discussion
    Last Post: 11-25-2017, 01:51 PM
  4. Rapid returns on Planar
    By Beansdiesel in forum BobCad-Cam
    Last Post: 02-19-2016, 03:52 PM
  5. New Zenbot Returns to Zero Z axis high
    By alterimage in forum Benchtop Machines
    Last Post: 03-30-2013, 05:46 AM
