588,044 active members*
3,453 visitors online*
Results 1 to 7 of 7
    Fanuc Spindle amplifier 08 alarm
    I am facing "08" fault on Fanuc Robodrill machine spindle amplifier, fault occurs intermittently and after a power restart it is ok. Once we replace the spindle amplifier entirely, machine is running fine until 3 months approx. Then we face the same issue again. To permanently solve this, what should I do?
    Dec 2009
    972
    Re: Fanuc Spindle amplifier 08 alarm
    what is the code of the spindle amplifier?
    A06B-6111-H015#H550 - Spindle amplifier
    Control card spec - A20B-2100-0800/080
    Quote Originally Posted by Hamilton44 View Post
    Alarm 08 means High input voltage.
    Input voltage seems not stable.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Dec 2015
    174
    SAME PROBLEM faced , found exactly in POWER PCB BOARD.
    Input voltage not stable as in machine overall supply or the power card? 3 months earlier we have replaced it as well.
    Jan 2024
    4
    Do you have the picture of the fault warning?
  1. Need Help!!! 03 Alarm on Spindle Amplifier
    By robbie0202 in forum Fanuc
    Last Post: 06-03-2023, 05:22 PM
  2. Replies: 1
    Last Post: 03-16-2015, 03:02 AM
  3. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  4. Fanuc spindle amplifier alarm 11
    By Eagle View in forum Fanuc
    Last Post: 05-15-2007, 11:10 AM
