588,465 active members*
4,974 visitors online*
Results 1 to 2 of 2
    4th axis path following error
    Hello !
    I am a bit new to cnc machining, I am trying to get my 4th (and 5th) axis to move along the other axis, I can use G01 with up to 4 axis simultaneously, however I noticed the 4th axis has a bit of a lag/advance no matter how small the G01 segments are.
    The only way to reduce error I found is to reduce the feed rate, in the video I increase the feed a bit and you can see the error increase as well. Then at the end of the trajectory, the error comes back to zero.
    I can see that the axis don't seem to start and stop at exactly the same time.
    Is it something to do with acceleration/deceleration, servo tuning, precision control, etc. I have no idea.
    Re: 4th axis path following error
    I found a solution for an unrelated problem here : https://www.cnczone.com/forums/fanuc/287144-cnc.html
    By putting all the accelerations (parameters 1620-1625) at the same rates for all the axes it pretty much solved the problem and reduced the error during movement by 95%.
  1. 4th axis master cam tool path problem
    By shahid8845 in forum Mastercam
    Last Post: 08-10-2021, 05:19 PM
  2. How to enable 4th Axis in Path Pilot
    By mofosheee in forum Tormach PathPilot™
    Last Post: 07-16-2021, 08:06 PM
  3. PCNC770 4th Axis with Clear Path Servo and PathPilot
    By charliebrumfield in forum Tormach Personal CNC Mill
    Last Post: 10-07-2017, 12:09 AM
  4. programming 4th axis helical path
    By Mike4703 in forum G-Code Programing
    Last Post: 08-12-2012, 08:29 AM
  5. 4th axis tool path depth cuts?
    By clivefx in forum Mastercam
    Last Post: 07-20-2011, 09:36 PM
