588,377 active members*
8,373 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > unrecoverable memory error
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Nov 2019
    6
    Yep. We did all that this evening. Like I said - a dry run
  2. #22
    May 2019
    21
    Re: unrecoverable memory error
    Hi All,
    I ran into a unrecoverable memory error at 007B today, but next to that I suspect some more memory issues.
    Before the memory error occurred already, when I looked at the tool table, the DT command shows very weird values (see attached picture)
    Also the parameters and the BL values were lost which I have to re-enter every time the machine starts (looks like at least a broken backup battery)
    Would a zero memory procedure be sufficient here or would these issues mean a new CPU board?
    Any help is very much appreciated
  3. #23
    Jun 2006
    241
    I got some really weird stuff on the screen after I pulled the memory board out to replace the battery. It took a few restarts before I could even get it to start up so I could zero the memory.
    I would definitely try the zero memory procedure. I would also recommend replacing the memory board battery if you don't know how old it is.
    This video shows how to replace the battery.
    https://youtu.be/OuYS4KLvQyk?si=DHiv9W20RDRymONw
    This is the battery on eBay https://www.ebay.com/itm/184450539247
Page 2 of 2 12
  1. Unrecoverable memory error
    By voytek1 in forum Fadal
    Last Post: 05-14-2021, 12:26 AM
  2. unrecoverable memory error
    By Michael82 in forum Fadal
    Last Post: 10-14-2009, 07:46 PM
  3. Out of memory error
    By zachf in forum BobCad-Cam
    Last Post: 07-31-2008, 02:22 PM
  4. EMC memory error
    By tomekbrzozowski in forum LinuxCNC (formerly EMC2)
    Last Post: 07-03-2006, 09:04 PM
