588,653 active members*
6,568 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Help with Flood Coolant / when to change? & possible health issue?
Results 1 to 6 of 6
    May 2007
    327
    I am using Coolmist water based flood coolant, about 10 gallons. Mixed about twice as think as need, have not noticed residue so I kept it fairly thick.
    I have an air bubbler that goes on a few hours a day and a SkimpySkimmer belt that goes on a couple hours a day and does a good job of taking out most of the oil, usually the flood coolant is almost clear/hazy.
    Woke up today with a pretty nasty chest pain, I am wondering if it is linked to breathing the coolant. The coolant is about June vintage? I do not use the mill all that much once or twice a month. How long can/should coolant last? Have I gone over the reasonable time?
    I am not using any stablizer, biocide, or ph balance right now...
    Thanks rich.
    Feb 2009
    41
    Rich,
    Since you are using a water base coolant (synthetic) the tank/shelf life is much longer than a semi-synthetic or soluble oil. Your are doing all the things right to maintain your coolant life so that is a big plus.
    We suggest to our customers to drop the tank, clean it, and recharge it with fresh coolant every 6-8 months. In your case, I would have to suggest the same.
    About your chest pain, everyone reacts differently when it comes to being in contact with coolant. Your chest pain could be a result in breathing too much vapor.
    Hope this helps bud.
    -Coolantman
    Jonathan Ballard
    EnviroServe Chemicals, Inc.
    www.EnviroServeChemicals.com
    (910) 892-1791
    May 2007
    327
    thanks
    Do you sell flood coolant? i need to be able to maintain the ph better as well. I will call you if so.
    Rich
    Feb 2009
    41
    I am a sales representative for a chemicals manufacturing company specializing in coolants. Please feel free to give me a call anytime. I will be glad to help any way I can.
    -Coolantman
    Jonathan Ballard
    (910) 892-1791 x25 office
    (910) 818-7412 cell
    www.enviroservechemicals.com
    Apr 2024
    Re: Help with Flood Coolant / when to change? & possible health issue?
    When it comes to flood coolant, understanding when to change it is crucial for both machine performance and operator health. Regular monitoring of coolant quality ensures optimal machining conditions while minimizing health risks associated with contaminated fluids. For comprehensive guidance on maintaining a safe working environment and maximizing efficiency, visit https://www.innovayogameditation.com/.
    Jun 2024
    Proper maintenance of flood coolant in machining is crucial to ensure effective cooling and lubrication. Over time, the coolant can become contaminated with metal particles, bacteria, and other substances, necessitating regular changes. Neglecting this can lead to equipment damage and potential health issues for operators, such as respiratory problems and skin irritation. When considering "wegovy dosing" for health management, it's important to also maintain a safe and clean work environment to mitigate additional health risks.
  1. Flood coolant option
    By truline in forum Haas Mills
    Last Post: 05-19-2011, 12:00 AM
  2. Coolant, Flood, Mist, WD-40, etc
    By Smitty911 in forum Benchtop Machines
    Last Post: 11-15-2009, 04:15 PM
  3. What is everyone using for Flood Coolant Filters?
    By CROSSHATCH in forum Benchtop Machines
    Last Post: 04-15-2008, 05:37 AM
  4. My SX3 flood coolant base
    By metalworkz in forum Syil Products
    Last Post: 09-16-2007, 10:24 PM
  5. question about flood coolant
    By nicad in forum MetalWork Discussion
    Last Post: 10-25-2005, 04:03 AM
