588,637 active members*
5,843 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP5020m DNC-B Baurate
Results 1 to 7 of 7
    Nov 2012
    4
    I have an OSP5020M with Dnc-B as baurate 4800, I want up to 9600 please help me ..... thanks
    Apr 2009
    1262
    Re: OSP5020m DNC-B Baurate
    You should be able to change Parameter word #39 to 9600 if using channel 1. Be sure to wait for about 2.5 minutes for backup to occur automatically and the power down including the breaker for 1 minute to let the RS board reset properly.
    Best regards,
    Nov 2012
    4
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    I change the parameter #39 to 9600 and backup (F7),=> restarted ... Everything has not changed...works only at 4800
    Apr 2009
    1262
    Then I would suspect that you are not using channel 1. Check your word#43 parameter to see what it is set to. I believe that is designating which port DNC will use. If 0 then using channel 0 and so forth. If 0 then try setting baud on word#6. Channels 2,3,4 are Word 40,41,42. Change the appropriate one as described before.
    Best regards,
    Nov 2012
    4
    Best regards,
    I did but the system still doesn't work at 9600.. (#6 9600, #39~42 9600, #43 0)
    Apr 2009
    1262
    Did you follow my exact instructions about powering down with breaker off for 1 minute?
    If you did then go to the parameter mode on the machine and type in CMPS and tell me if some “magic” DNC parameters open up.
    Jun 2020
    67
    can you tell me what type of dnc-b you use for your osp5020? Thank you
  1. Okuma mc-4va OSP5020M - dnc - new to cnc
    By Thoreng in forum Okuma
    Last Post: 02-10-2019, 10:08 AM
  2. Okuma MC 4VA OSP5020M
    By Patoruzo in forum Milling
    Last Post: 11-15-2016, 04:27 PM
  3. OKUMA OSP5020M HELP
    By KENNY D in forum Okuma
    Last Post: 05-18-2014, 04:12 AM
  4. MC-500H osp5020M - 139 alarm A
    By cnc312 in forum Okuma
    Last Post: 09-11-2013, 08:53 PM
  5. need osp5020m manuals
    By guydrisc in forum Okuma
    Last Post: 11-01-2010, 05:48 AM
