588,606 active members*
8,087 visitors online*
Results 1 to 14 of 14
    Mar 2024
    14
    Hurco hawk 5ssm
    Currently i have a hurco hawk that has a cmos check sum error.
    Reaching out for any help i cam get to get this rest.
    On the main screen its asking for F1 to be pressed which on the monitor doesn't do anything.
    I have a Ps2 keyboard but no adaptor yet for the db9 serial port on the electrical cabinet
    The computer boots with 2 beeps and the screen loads up to the stage of the cmos checl sum error press F1.
    The machine did run fine maybe 3 years ago but has been off power since then
    Attached Thumbnails Attached Thumbnails IMG_20240320_202824.jpg   IMG_20240317_175107.jpg
    Mar 2024
    14
    Ok so i got a keyboard hooked up managed to press f1 and got into the Cmos settings i followed a hurco service bulletin and went through all the standard and advanced settings.
    I copied what bloke suggested in another post for the cylinder heads 1223 sect 50 etc amd manged to boot the system.
    It brings me to the part set up screen and the progam screen
    But the main controller none of the buttons work i can only use the keyboard.
    It wont allow me to press manual power, cycle start to enable the drivers.
    Its like the machine has forgot ot has the controller all the parameters needed to set it up arent there.
    Really need help here if anyone even reads these anymore.
    Mar 2024
    14
    Re: Hurco hawk 5ssm
    Just wanted to add pictures of the CMOS, advanced CMOS, Peripheral, chipset settings hopefully someone can help.
    Were a small start up company and I've contacted Hurco who basically said we don't really have anyone that can support this machine due to its age and the knowledge bass isn't working there anymore.
    Basically they have no one that knows these systems anymore,
    Attached Thumbnails Attached Thumbnails WhatsApp Image 2024-06-16 at 21.40.06 (1).jpg   WhatsApp Image 2024-06-16 at 21.40.06 (2).jpg   WhatsApp Image 2024-06-16 at 21.40.06.jpg   WhatsApp Image 2024-06-16 at 21.40.07 (1).jpg
    Mar 2024
    14
    Re: Hurco hawk 5ssm
    Help please
    Mar 2024
    14
    Re: Hurco hawk 5ssm
    Additional pictures
    Mar 2024
    14
    Re: Hurco hawk 5ssm
    Additional Photos
    Jun 2008
    1108
    Re: Hurco hawk 5ssm
    I’ll see if I can find some settings for that CPU from my old mates at Hurco.
    Mar 2024
    14
    That would be great if you can,
    Thanks bloke
    Jun 2008
    1108
    Re: Hurco hawk 5ssm
    Looking at your pictures, it may be that the Canbus Controller has been interfered with. There is usually a 10 way ribbon cable between the edge of the board and the DCIO backplane board (the one that the IO/IF board is plugged into)
    Mar 2024
    14
    Quote Originally Posted by bloke View Post
    Is that the blue connector shown in this picture, if thats correct i removed it to get better pictures of the boards so i could see part numbers
    Jun 2008
    1108
    Re: Hurco hawk 5ssm
    No. The connector near the red LED.
    Jun 2008
    1108
    Re: Hurco hawk 5ssm
    It should plug into the backplane for the I/O cards - right at the back by the smaller yellow circle.
    Jun 2008
    1108
    Re: Hurco hawk 5ssm
    If your keyboard isn’t working, it could be the Canbus Controller is faulty.
    Mar 2024
    14
    The keyboard ive plugged in works just the main control panel once the machine boots up dosent take over.
    Even though when its booted the front panel seems to initialise fine.
    I see the cable port you're looking at but its not here unless the previous owner removed it i dont have it are you sure thats definitely missing
    Attached Thumbnails Attached Thumbnails IMG_20240702_194422.jpg   IMG_20240702_195133.jpg
  1. Hurco Hawk 5M
    By Taz2012 in forum HURCO
    Last Post: 06-23-2024, 10:24 PM
  2. hurco hawk 5m
    By lopez473 in forum Spanish
    Last Post: 07-31-2014, 07:56 PM
  3. Replies: 0
    Last Post: 01-27-2014, 10:18 PM
  4. Hawk 5SSM CNC UltraMax 3
    By xtrmestylin in forum HURCO
    Last Post: 04-18-2009, 02:24 AM
  5. Hurco Hawk 5D
    By sensph in forum HURCO
    Last Post: 09-22-2008, 06:02 PM
