588,532 active members*
8,240 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Has anyone looked at the "JET" or "Shop Fox" manual machines?
Results 1 to 13 of 13
    Jan 2007
    46
    Just wondering cause I was looking at getting one and then converting to CNC...
    link of the general machine
    http://cgi.ebay.com/ws/eBayISAPI.dll...1836&rd=1&rd=1
    or
    http://cgi.ebay.com/ws/eBayISAPI.dll...4779&rd=1&rd=1
    Jan 2006
    4396
    Stay away from JET Machines. They are made with the same quality specs as ENCO, but just cost more $$$.
    http://www.use-enco.com/CGI/INSRHM?KNC-DV6174368836
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jan 2007
    46
    Quote Originally Posted by tobyaxis View Post
    Thanks I have never even heard of Enco...
    I am not really looking for top quality right out of the gate, but good enough to use for right now while getting started and building capital for bigger/better...
    49
    Mill or Lathe , I have not had any problems with my jet lathe keeping in mind I use it in my home shop and yes it has seen some abuse I have been in the machining profession for 20 + years and it seems to me that as always people blame the machine and not the person operating it , as for the second part of your question I can't help you , but were there is a will there is a way.
    Oct 2004
    3
    Nov 2004
    202
    I have a Jet Gear Head 13 inch lathe and I'm very satisfied. I choose Jet because of their reputation for service and support. Cheaper versions of the "same" lathe might not have the same level of precision. i.e. TIR and bed flatness etc. Also I bought my machine through Production Tool Supply they have always given me outstanding service. They have fixed problems with no quesrions asked.
    Jan 2007
    46
    Quote Originally Posted by DocHod View Post
    Sorry I should have clarified I was looking at Mills right now, but lathes are not far behind (hopefully).
    I am basically looking at starting a full fab shop. That with a good mill and lathe be able to make any other machine and tooling that I might need.
    Jan 2006
    4396
    Toby D.
    Schwarzwald
    May 2006
    9
    Take a look at the Grizzly G3103 same thing as Shop Fox but for less money.
    http://www.grizzly.com/products/G3103
    Jun 2006
    4
    This is not a bad gear drive benchtop mill. I recently converted mine to 4 axis cnc. I did some minor changes to improve accuracy to a satisfactory level without a ball screw conversion. The price is right
    http://http://www.wttool.com/product...n_Swivel_Table
    Jan 2007
    46
    Quote Originally Posted by geh1 View Post
    Actually I really like that one.
    One of the main things I like is the geared head, instead of belts.
    Would you mind telling me some og the things you did to tighen it up? I will probably be ordering this one within 3 weeks.
    Jun 2006
    4
    Hey Boosted. the primary problem, "and not a big one to fix" with this machine is that there is no preload on the bearings that locate the drive screws to the table. The collars are simply pinned to the shaft. You can simply remove the pins and place a bolt in the end of the shaft 'wich is pre drilled and tapped already' with a pressure washer to give the desired preload. I went from .012 to .0025 backlash with this simple fix. Be advised that the bearings are not designed for extreme force and in the future should be replaced with a good angle bearing block assembel but this will get you started with a a fairly close tolerance machine at a fraction of the cost. Good enough to make something better with. -G-
    Jan 2007
    46
    I think I will be going with an enco one that is +/- a grand.
    That should be good for now and leave me plenty of cash left (of a budget of about 2K) to convert to cnc, buy a few sets of bits and do some upgrades to the mill to make it a little more than decent.
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum Community Club House
    Last Post: 05-18-2008, 03:53 PM
  3. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
