603,337 active members*
4,451 visitors online*
Results 1 to 5 of 5
    Oct 2018
    5
    UC300ETH to stepper drvier
    Good evening. My Gecko 540 recently died. I tried to make repairs, but it was more than just the two output MOSFETs. I am trying to go with some other driver for my CNC. They are the same ones I am using on my laser engraver, and they seem to work well. I just have a question on the on-the-power to them. I am using the driver that is attached to this post. My question is for the Pull+ and Dir+: do I have to use 5V, or can I use 12V? I am coming directly off of a breakout board from the UC300ETH to the drivers. I don't want to put like 12V and fry my UC300ETH. Right now, I am using 5V because I have a 5V converter.
    Thanks,
    Justin
    Re: UC300ETH to stepper drvier
    Quote Originally Posted by yagodajm View Post
    Thanks,
    Justin
    Stick with 5V for the Pull+ and Dir+ signals from your UC300ETH to the drivers,
    and you’ll be safe! If your drivers are marked for 12V and you feel confident in their specs,
    you could technically use 12V, but it’s best to align with 5V logic to avoid any risk to your UC300ETH.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Nov 2013
    5404
    you'd be better still using some sort of breakout board, going direct from the UC300 is asking for trouble.
    Craig
    Oct 2018
    5
    Quote Originally Posted by cncmakers001 View Post
    Thank you, I was not sure it the uc300eth was controlling everything through the ground or through the +5v. I know on the gecko, it would break the ground wire.
    Oct 2018
    5
    Craig
    So I have my uc300 on a mobo and that goes out to a standard breakout board. I am not sure if I need something more then that or not. Attached it the mobile and breakout board I am using.
    Thanks,
    Justin
  1. UC300ETH Pin OUt
    By SamHam in forum UCCNC Control Software
    Last Post: 12-22-2020, 01:21 PM
  2. 5V power for UC300ETH
    By Titaniumboy in forum UCCNC Control Software
    Last Post: 07-05-2020, 09:16 AM
  3. Replies: 0
    Last Post: 09-11-2019, 10:17 AM
  4. UC300ETH-5LPT with MX3660 - Crazy Stepper motor behavior. Need help
    By Colt4587 in forum UCCNC Control Software
    Last Post: 03-04-2019, 01:45 AM
  5. UC300ETH-UB1?
    By KurtRosenzweig in forum Chinese Machines
    Last Post: 06-23-2018, 01:30 PM
