603,310 active members*
2,992 visitors online*
Page 4 of 4 234
Results 61 to 69 of 69
  1. #61
    Apr 2013
    1916
    Re: UCCNC Macro sharing
    Quote Originally Posted by asuratman View Post
    Do I need to learn all C language or just instruction on above folder ?
    Macro_capability_detailed.htm is a file, not a folder. Click on it and you will see what's in it. Not really instructions, just description of the functions supported by UCCNC. You need much more than that to learn, at least if you define "learning" as equal to knowing something, not just making small simple changes. Macro_capability_detailed.htm is not a teaching aid, it is intended to help those who know how to program, a user guide for programmers.
  2. #62
    Sep 2005
    1198
    Thanks Gery and a_camera for the feedback. I just finished installing uccnc on my mill, its working ... Now, I try to program macro to customize my cnc mill, its fun if I can do it myself. UC300ETH combined with UCCNC is good and not complicated.
  3. #63
    I need help with the mobile/fixed probe setup. I only find x,y coords in m31 part for fixed probe location. Mine is 250 mm above work area. I made it work by setting retraction to this value, but that has to be edited every time. I need a way to add a z in machine to send the second half of the m31 macro for fixed location. How do I provide that
  4. #64
    Hey I got your screen working. I had an error caused by my retration not being fast enough. I set feed rate too low. bumped it up and the active probe error went away. this happened even with and end mill not switching probe. probably tiny filings on tip. Nice work!
  5. #65
    Hello Mr. Andy!
    Thank you so much for sharing your Tool Change Probe "Macro". Everything is working perfectly fine.
    I'm new to UCCNC software, and I can't get their tool change probe routines to work.
    So, I'm really happy to have found you!
    Thanks again mr. Andy
  6. #66
    Aug 2020
    Quote Originally Posted by derek View Post
    Has anyone here migrated from Mach3 to UCCNC? I have a number of custom macros I want to convert from VB to C#. I'm not well versed in either but I thought that it would be nice to see if anyone else is converting.
    Derek
    Hi Andy, thanks for sharing your macros.
    I'm going to try your macros and see if I can get them to work for me, as I'm very new to CNC.
    Cheers Dandy
  7. #67
    Mar 2016
    16
    using these macros for my toolchanges , they are working well for me , a few things i need some help with are when i run the m6 command the spindle goes to the tool change location and then goes to the fixed probe, probes and then returns to 5mm above the part ,i would like this gap to be more .,,also when running gcode with differant tools involved ,at the m6 command in the gcode the machine goes to the toolchange location then probes the fixed plate but does not continue on with the cutting ...maybe a post processor issue , i was using gcode atc mm.tap as the post processor..
  8. #68
    Mar 2016
    16
    i have just found these macros ,,, thanks ...going to try them out in the next few days.
Page 4 of 4 234
  1. UCCNC owners and support thread
    By shorton in forum UCCNC Control Software
    Last Post: 08-25-2017, 12:07 AM
  2. Getting Started with UCCNC Software
    By BanduraMaker in forum UCCNC Control Software
    Last Post: 02-08-2015, 07:06 PM
  3. UCCNC software released for sales
    By dubble in forum News Announcements
    Last Post: 08-05-2014, 11:25 AM
  4. UCCNC software release
    Last Post: 06-13-2014, 02:24 PM
  5. Sharing a tool offset verification macro
    By dpuch in forum Parametric Programing
    Last Post: 08-02-2010, 09:46 PM
