Originally Posted by
dylancw
Here's the problem right now. When the lathe starts up, it says that I have to home the tailstock and X and Z axes. I have to hold OT release to move the X and Z axis at all. I can not get them to register home position, I have checked the home and overtravel switches and they work.
The tailstock only moves away from the headstock, it will not move toward it. But I tested the relay and the hydraulic solenoid valve on the other direction and they work. Also, when I press "T-" the button press shows up in the Diag panel as one of the bits toggling 0->1 but the LED on the button does not come on. "T+" LED does light up.
Also, the turret change function used to work but does not work any longer...
Hmm... Not my favorite control right now, there's so little documentation.
