587,998 active members*
1,697 visitors online*
Results 1 to 5 of 5
    Aug 2006
    98
    G10L50 In FANUC 18IMB
    Guys, i need an help. I try change an parameter by mdi mode or in automatic mode and nothing happens. I read in manual thats possible change and some peoples says thats an optional, but these optional is instaleed, because its possible change other parameters. The parameter that i need change is 4026. I try change 1322 and it´s possible change, but when i try change 4026, nothing !!! Any people try change that ???
    Program that nothing happens
    G10L50
    N4026R10
    G11
    Program that change the value
    G10L50
    N1322R1000
    G11
    Thanks a lot
    Daniel
    2932
    According to my 18iMB parameter manual, #4026 is a parameter for the Serial Spindle Interface (something to do with a load detection signal). It's possible these can't be changed with a G10.
    #1322 is a Stored Stroke Limit parameter, and it makes some sense that you could change that during a program.
    Aug 2006
    98
    Dcoupar,
    If you see in the Parameter Manual, number B63530EN2, page 226, says that´s possible change these parameter using G10. I try change these parameter in AUTOMATIC mode to to an torque control. If i use these parameter, it´s possible i receive an word from PLC (F45#4) that the torque is more then the value in the parameter. See that and tells me.
    Daniel
    2932
    My parameter manual is 03, not 02. I don't find any reference to those parameters on p226.
    Aug 2006
    98
    It´s possible change !!! Use
    G10L50
    N4026P1R3
    G11
    It´s ok !!!
    Daniel
  1. FANUC & GE FANUC Repairs
    By RRL in forum News Announcements
    Last Post: 04-17-2011, 05:50 PM
