Originally posted by HaWee
Ballendo,
After having some contact with Paul Jones I got a schematic drawing where i can see were to put the wires.
The drawing was only untill the TIP120.....the rest above the TIP is drawn by me (just on paper...don't know what programm to use yet...!!) but I used the layout also from Paul jones freebies.
Do you guys think this is complete? Nothing to add?
R2 is added also by Paul Jones, but I don't know exactly how to calculate this one....for the Power Limit Resistor I got the programm stepCalc (also from Paul..thanks a lot Paul!!!).
can I start building like this???? or something else to improve??
Btw. i opened a new thread on help for the SLA7052M, this IC I think works the same as the 5804, but has a lot more stuff build inside, and can handle 3A...why doesn't anyone use this one??
How to connect this one...do I have to add something to it?
Just FYI,
If you used Steppercalc, in theis configuration you need to select "one resistor" as an option as well as "transistors" for the output option. You can also put one resistor on each motor winding (two per motor), which results in lower wattage resistors. Sometimes the high wattage resistors are more money or harder to find.
Eric
BTW, I am the author of Steppercalc.
I wish it wouldn't crash.
