587,231 active members*
4,748 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Jan 2006
    52
    8020 Router, It's Finally Alive!
    Well finally after 4 months of hour here and hour there work it's alive!
    Size
    X = 42"
    Y = 26"
    Z = 16"
    I don't honestly know what size cutting area I ended up with and I haven't had the chance to measure the final size.
    Total Build Cost $1400 including router.
    Parts Used
    THK, IKO Rails - Used from EBay
    8020 - Surplus from EBay
    Anti-backlash nuts - DumpsterCNC
    Solid delrin couplers - DumpsterCNC
    1/2-10 TPI Acme Threaded Rod - Enco
    Nema35 motor mounts - EBay
    280oz/in Nema35 Steppers - Kelinginc
    G201 Geckodrives - EBay
    Hitachi Router Mount - K2CNC
    M12VC Hitachi Router - Lowes
    PMDX Breakout Board - PMDX
    I'm still in the process of aligning and tuning but i've had it cutting and so far it looks great.
    First Cut Video
    Second Cut Video
    Jan 2007
    18
    Great job!!
    Jan 2006
    153
    Hmm.. Something looks wrong on the Z or is it just the way it looks in the picture, but the router goes up and down but the mount (y) stays down and you don't have any clearance.
    Jan 2006
    52
    Quote Originally Posted by Netjams View Post
    lol I know, I had only about 1" of clearance in the pictures. But since moved it up.
    Nov 2004
    321
    Netjams: I also noticed that about z axis.
    Dec 2006
    277
    Thanks for the very detailed photo's of your z axis, I am just designing one here and the detail is very useful. Thanks
    Bob
    Jan 2006
    52
    Quote Originally Posted by bobcrockford View Post
    Bob
    Your welcome
    Thats the only hard part when you design something from scratch, helps to have a little guidance.
    May 2006
    954
    Looks really slick. Would like to see vids when you get it running!
    Apr 2006
    20
    Great machine. Thanks for share.
    Jan 2006
    52
    Quote Originally Posted by bp092 View Post
    Thanks!
    I had posted some videos right above the first picture, I will be adding some more once I get the hang of the machine. I'm really struggling right now with tool and table offsets so once I get that figured out i'll be golden.
    May 2006
    954
    Quote Originally Posted by jcdillin View Post
    Thanks!
    Looks really nice, sorry I missed that link, was tired when I first replied. Router looks familiar :rainfro: if only CNCZone had a deal worked with Hitachi, I think like half the members here with DIY routers used that router as their spindle. If you need help with setting up work offsets and figuring things out let me know, maybe I can help you. We have all been there, and even though mach3 is very simple and easy to use, there is still much to figure out in general about how you want to work your machine. I started with throwing the stuff in the middle and zeroing on the piece and now I figured out the best way to optimize my machine just with experience. Send me a PM if you need any help, I believe you are using mach3 because I saw you cutting what looked like the roadrunner gcode file.
    Jan 2006
    52
    :lol: Yeah it's almost a no brainer being that the router is only $100 from lowes and the mount is only $50 from K2 makes for a very simple and easy spindle.
    I'll send you a PM because at this point I have the X and Y offsets figured out no problem. It's the Z axis that is giving me the major headache.
    Thanks!
    Jan 2006
    153
    It does look like you did a really good job building it.
    Jan 2006
    52
    Thanks!
    I never imagined I could build something like this, it's been such an amazing experience. I can't wait to build a CNC mill next.
    Jan 2006
    153
    After a closer look you could raise the Y up a few inches or so, and then ad a plate extending down on the Z and that would give you a few more inches if Y/Z clearance. I see you already have enough Z travel that is just going to waist now.
    I sure wish I had the bucks to build one just like it!
    Dec 2006
    277
    Hi Again
    In the second last photo:
    Is there a piece of packing between the bearing block's and the front plate. I can just see something protruding at the top of the bearing block. How thick is it?
    I take it that you needed a little more clearance than the bearing block's themselves would allow for your ball nut clearance beween the Y and Z axis.
    I'm very close to making a start now. The frame is being cut and I have nearly got everything all here or coming here so it's just a matter of hurry up and wait I have only got the use of the left arm now (was RH before) as I had a rather bad stroke about 5 years ago so the build log will be interesting when I make a start on it. I am using ITEM which is pretty close to 8020 and I got a good price too.
    Keep up the good work!
    Bob
    Jan 2006
    52
    Yes you are correct and now i have the machine running i plan on using it to cut the aluminum plate out to make it that way along with making it stronger and more accurate.
    Thanks for the suggestions though!
    Jan 2006
    153
    It looks like you mastered that part
    Jan 2006
    52
    Hi Again
    Bob
    You are correct, since I didnt want the nema35 mount overlapping the backplate I had to space the plate up from the trucks. I'm using just another peice of 1/4" alum plate as a spacer.
    Jan 2006
    52
    :wave: i'm almost there I set the machine to cut a circle 6" in diameter it cut a circle that was 6.014".
    I think I just need to tighten a few bolts and shorten the X axis leadscrew nut support. Or I might have just had some play in my sacrifical peice of wood.
Page 1 of 2 12
  1. Second router finished - 8020 Bearings
    By Hack in forum DIY CNC Router Table Machines
    Last Post: 04-25-2017, 03:41 AM
  2. Ahren's 8020 Router
    By ahren in forum CNC Wood Router Project Log
    Last Post: 09-24-2007, 04:10 AM
  3. 8020 cnc router table top
    By eloid in forum CNC Wood Router Project Log
    Last Post: 02-25-2007, 02:32 AM
  4. My first router - Finally!
    By raiven in forum CNC Wood Router Project Log
    Last Post: 10-20-2006, 11:29 PM
  5. Results from using 8020 for a CNC router
    By WarrenW in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 01-06-2006, 03:17 AM
